Cold no start
Old Feb 24, 2018 | 02:50 PM
pebell's Avatar
pebell
Cold no start
Hey everyone I just joined and thanks for having me. I have a 2003 6.0 that cranks but won’t start. Truck has had new injectors new fuel pump egr delete and turbo cleaned new ficm and batteries within last 5 yrs. truck has 178k miles on it and sits for weeks at a time. Truck ran fine and I shut it off, went to start it a few days later and now she just cranks. I have the live wire tuner and it shows on crank only 9 volts from battery and injector pressure at 9 as well. The ficm is only at 11. I know these numbers are way off and was wondering what you all think could be causing it. At first I assumed bad icp and or IPR but now I’m thinking maybe batteries as well. Don’t want to change out good parts so any help will be greatly appreciated
Old Feb 24, 2018 | 04:38 PM
xcrsp440's Avatar
xcrsp440
Need to start with good batteries. All the downstream electrical stuff relies on them. Put a charger on and after charging, take them to a parts store and have them load tested.
Old Feb 25, 2018 | 05:59 PM
pebell's Avatar
pebell
Batteries are good now. Still not getting 12v when cranking. Any ideas
Old Feb 25, 2018 | 06:12 PM
bismic's Avatar
bismic
Did you load test them as suggested? All the cables clean and tight (including grounds)?
You probably won't be at 12V when cranking, but you should be at 10.5 or so. Below 10 is not good at all.
Old Feb 25, 2018 | 07:08 PM
pebell's Avatar
pebell
Brand new batteries. It stays above 10 but below 12v when cranking. I was told I needed 12v to fire the ficm? Not sure what is going on with this thing.
Old Feb 25, 2018 | 07:11 PM
bismic's Avatar
bismic
The FICM will do fine with the 10.5 (even close to 10) when cranking .... if it is healthy, and not for a long time. Since you had very low voltage before, the FICM is likely to be damaged, IMO anyway.
Old Feb 25, 2018 | 07:13 PM
pebell's Avatar
pebell
How do I test the ficm?
Old Feb 25, 2018 | 07:14 PM
bismic's Avatar
bismic
You need 47.5V on the output power voltage (MPower) from the FICM. However, there is a logic side that can fail also.
My choice would be to send it to FICMrepair.com for testing.
Old Feb 25, 2018 | 07:15 PM
pebell's Avatar
pebell
Thanks for the help bud
DougJ_1997PSD
Jul 16, 2017 08:50 PM
mark227
Dec 16, 2016 12:17 PM
Bvteachey05
Jun 20, 2016 09:03 AM
mark6x43
Oct 26, 2009 07:24 PM
jmr420
Aug 23, 2005 12:13 PM
