Blue plug E4OD?
Old Feb 23, 2018 | 06:30 PM
Jamegan's Avatar
Jamegan
Blue plug E4OD?
Mysterious blue plug laying on top of my E4OD; right above the shift solenoid on the passenger side.
Anyone know what it goes to? Or what it is for?
Thanks!
https://imgur.com/gallery/8Ak03
Old Feb 23, 2018 | 07:28 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Looks like the type of plug used for oxygen sensors.
Old Feb 23, 2018 | 07:37 PM
Jamegan's Avatar
Jamegan
Interesting! The previous owner hacked the exhaust off at basically the manifold and welded up a homemade exhaust, very poorly. So that could very well be it.
Old Feb 23, 2018 | 07:49 PM
Da_Lariat_Chariot
I can almost guarantee that's the case. A missing O2 sensor will throw some codes and a check engine light.
Old Feb 23, 2018 | 08:04 PM
Jamegan's Avatar
Jamegan
P0136
P0141
P0171
P0174
I believe those are all O2 sensor related Unfortunately he didn’t weld a catalytic converter on, just a straight pipe with a muffler from the manifold. And my luck would have it that the missing O2 sensor would probably be after the catalytic converter I bet lol
Old Feb 23, 2018 | 10:16 PM
McLeod's Avatar
McLeod
A '96 O2 sensor is before the catalytic converter...
Old Feb 23, 2018 | 10:21 PM
Da_Lariat_Chariot
My recommendation would be to undo the previous work done, get a new catalytic system and manifolds if they are damaged. Magnaflow makes direct fit units and maybe you could do headers, make it scream a bit. 😁
Old Feb 23, 2018 | 10:29 PM
wtroger's Avatar
wtroger
At least weld in the o2 sensor bungs on each side and put o2 sensors in.
Old Feb 23, 2018 | 10:53 PM
Lead Head's Avatar
Lead Head
A 96 F-150 or Bronco will have a second O2 after the cat.
Old Feb 24, 2018 | 04:20 AM
Jamegan's Avatar
Jamegan
Even on the 4.9L inline 6?
Old Feb 25, 2018 | 08:15 AM
Lead Head's Avatar
Lead Head
All 96 F-150 and Broncos have an O2 sensor after the cat.
Old Feb 25, 2018 | 10:39 AM
rla2005's Avatar
rla2005
I believe there are three O2 sensors on a 1996 4.9L F150. Bank 1 is in the front three exhaust pipes/collector. Bank 2 is in the rear three.
The third sensor is behind the converter. It's only used to calculate converter efficiency.
eg1031
Aug 19, 2013 08:55 PM
dirtfrmr57
May 14, 2012 07:25 PM
dt69999
Oct 6, 2010 02:42 PM
jc
Sep 18, 1999 08:34 PM
