need help with koeo codes...
Old Aug 19, 2013 | 11:57 AM
eg1031's Avatar
eg1031
i just recently bought a e4od transmission for my 95 f150 5.8 seems to work fine ....
i also bought a code reader and did a koeo test and it pulled a few code
558
622
629
626 2nd test
could the codes mean i need solenoid pack or my plugs are not plugged in right or dirty?
Old Aug 19, 2013 | 03:12 PM
subford's Avatar
subford
What transmission did it have in it before?
If it was an E4OD I would say you have a bad plug on the passenger side of the transmission.
Pull the back cover off the plug and look at the wires going into the plug.
Old Aug 19, 2013 | 08:28 PM
eg1031's Avatar
eg1031
it had an e4od but it never shifted to 3rd gear or torque converter never locked up so i went and got another one from salvage yard...
the old one never threw codes like that i started getting the codes with the new transmission..
would it matter if the eec is from a 4x4 e4od?
Old Aug 19, 2013 | 08:40 PM
subford's Avatar
subford
Not as long it was from the same size engine of about the same year.
I would still look at that plug as can cause a lot of problems from the exhaust heat from where it is located. Make sure the heat shield is in place also over it.
Old Aug 19, 2013 | 08:55 PM
eg1031's Avatar
eg1031
ill probably have to clean the plugs it might not get enough contact with the pins ...
the truck runs fine shifts good but i just dont like the codes i get with my scanner i bought....the code only pops up when i do the koeo test they are not stored codes just when it checks every thing..
Boofracinginc
Mar 29, 2016 07:27 AM
Forddiesel17
Jan 4, 2012 08:52 AM
kiohio1985
Aug 30, 2006 08:20 AM
JCATC
Apr 8, 2004 07:15 AM
