Looks like the type of plug used for oxygen sensors.
Interesting! The previous owner hacked the exhaust off at basically the manifold and welded up a homemade exhaust, very poorly. So that could very well be it.
I can almost guarantee that's the case. A missing O2 sensor will throw some codes and a check engine light.
P0136
P0141
P0171
P0174
I believe those are all O2 sensor related Unfortunately he didn’t weld a catalytic converter on, just a straight pipe with a muffler from the manifold. And my luck would have it that the missing O2 sensor would probably be after the catalytic converter I bet lol
My recommendation would be to undo the previous work done, get a new catalytic system and manifolds if they are damaged. Magnaflow makes direct fit units and maybe you could do headers, make it scream a bit. 😁
