Best Modifications Under $50
Don't forget to post links so other idiots can part ways with their money as well!
Forscan spreadsheet is free, user instructions free, work laptop with Bluetooth, OBD2 Bluetooth MX was $60 CDN free shipping Amazon prime and I have done four mods so far:
1. TPMS settings to 60 psi front, 65 psi rear.
2. Bambi mode, driving lights on with high beams. (LED Headlights and driving light skin)
3. Remove double horn honk when leaving truck running and exit.
4. Police secure mode, can't remove from park if FOB in pocket and not in the vehicle.
Several more I plan to do, once you have it working, it's really slick.
I also ordered the locking fuel cap, 40 bucks, to secure almost $350 worth of diesel and avoids DOF getting into fuel at dealer cause I don't tell them where the key is.
http://www.amazon.com/gp/aw/d/B01N18TOFB/ref=oh_aui_i_sh_in_o1_img?ie=UTF8&psc=1
I also got some cheap LED pods for when I'm hooking up the toy hauler in the desert. They are $49 for two...I got them for $20 for 4... So watch for a sale!
http://www.amazon.com/gp/aw/d/B00LQ04N2Y?psc=1&ref=yo_pop_mb_pd_t1
Homemade Raptor lights: Three bolt style LED lights are $3.95 each, I drilled holes 9" apart in a piece of aluminum, painted it black and secured it behind the grill with two small screws. Wired the lights to the brown hot in run wire in the upfitter bundle.
https://www.superbrightleds.com/more...ght/1494/3436/
#1 tailgate shock, IMO best mod you can do, under $30
#2 Toughskins superduty letter inserts under $50 for each set and
#3 unpainted mirror cover caps from ebay HERE and got them painted to match the oxford white, $25 each, gives it the platinum look, ish... either way I like the look.
#4 LED underglow light strips connected to the plugs on each side below the truck. Lights up when opens door then fades out when door closes. Might be a little blingly for some, but you will never loose anything under the truck in the dark.
Plug adapters the light strips I did use small 3m double sided tape to secure them better than the basic adhesion on the strip, HERE
#5 Rear LED lights hooked to a switch mounted on my hitch (these do not fog up like others I bought and mounted in my grill)
#6 A 40$ switch panel to control all the lights and other things (you all have up fitters so I made downfitters in a little box I custom built to fit in the floor) Panel
#7 a cell phone cradle that clips on my vent from autozone for $10
#8 a remote bass **** to adjust my subwoofer levels on the fly (rest of the stereo was well above 50)
I also have Interior and wheel well lights for under 50 bucks I just don't remember the link I used to get them, they are controlled on the switch and not door activated. Turns out I never use them, maybe next summer on the beach or something.
Here is the above $50 list just to break the thread rules
Coverking kryptek typhoon seat covers
Zone dual steering stabilizer
2.5" lift
35" tires & rockstar rims
bushwhacker flares
12" sundown audio woofer in custom underseat box & rockford p500 amp
weathertech front and rear floor mats (BUY HUSKY INSTEAD, it is impossible to scrub these things clean..)
front window tint @ 20$ (was $75 laser cut and installed)
Some pics of some of the things.
