Best Modifications Under $50
Old Feb 24, 2018 | 08:32 AM
  #46
grege's Avatar
grege
Originally Posted by kho6658
It takes a little work to position it in, but it does fit.
Is the work because it is tight? Oh and your mat behind the coin area looks turned wrong. lol
FYI I saw on F150 forum where somebody got a black handle and added it to the middle to make taking it out easier. That was the biggest complaint I saw on reviews.
Old Feb 24, 2018 | 08:41 AM
  #47
jsavelli's Avatar
jsavelli
Originally Posted by danr1707
This is all I needed, other than some wire, solder, wire loom, etc. I used the 20K Ohm 1 watt as recommended. Price is $1 for 10 of them.
There are several threads on this.
thx. U mind me ask were u ran wire?
Old Feb 24, 2018 | 08:47 AM
  #48
kho6658's Avatar
kho6658
Yes, it is a tight fit to get between the two sides. Once in, not a problem. I have taken it out a few times as my wife likes to hide her purse under it. Reason why the mat is turned the wrong way.
Old Feb 24, 2018 | 09:11 AM
  #49
danr1707's Avatar
danr1707
That's a good question. I first ran the wire across the fire wall. Bad idea. The wire loom melted.
I ended up running it to the front of the engine and across the radiator. That's been good. Amazing that the up-fitter connections are on opposite side of the pass-throughs.
Old Feb 24, 2018 | 12:52 PM
  #50
jsavelli's Avatar
jsavelli
You put wire loom back on ? and ran through on top of radiator or behind? I was not sure if there was a way to run under gasket along underneath wipers n vents?
I'll have to look when I get off shift. I never used resistors so this is a new one for me. Thx
Also what wires did you put 20k in between. Confused....do I connect 20k to wire white/violet and connect to a pass through wire then run that pass through wire to upfitter 4. Push park brake then flip upfitter 4 and shpuld be good??? thx
Old Feb 24, 2018 | 02:27 PM
  #51
AMXDREAMER's Avatar
AMXDREAMER
Console organiser off Ebay
Old Feb 24, 2018 | 05:01 PM
  #52
saskowner's Avatar
saskowner
Wish I had read this before I ordered one.
Gary
Old Feb 24, 2018 | 11:25 PM
  #53
Platinum18's Avatar
Platinum18
I bought the Platinum inserts for the tail gate. $49.99. I think it makes it trim out nice and clean!
Video:
Old Feb 25, 2018 | 06:54 AM
  #54
Greengas's Avatar
Greengas
great list
Following.
Old Feb 25, 2018 | 07:38 AM
  #55
Larrymac52's Avatar
Larrymac52
Originally Posted by Tricon
So my last truck we had one of these threads going and you wouldn't believe how many amazing mods you can do for cheap. It probably cost me more money than anything else. I searched and didn't find anything here, so we'll give it a go.
Post anything awesome you've done to your truck for under $50. I'll start with a few:
Stubby Antenna: $25
http://www.amazon.com/ORIGINAL-1999-...for+ford+f-250
Plasti-dipped Side Emblems: $6 for a can of Plastidip
BuiltRight Driver side seat release: $33
http://www.builtrightind.com/product...r-seat-release
Console Organizer: $30
http://www.ebay.com/itm/Black-Interi....c100005.m1851
two questions here.
i don’t understand the seat release ? What is it’s application?
also the organizing tray, what happens with all the space below— you have to lift that entire tray out or does it slide into some space?
Old Feb 25, 2018 | 08:05 AM
  #56
xxxsherpa's Avatar
xxxsherpa
The rear drivers side seat folds forward. There is a small latch pin you have to slide to release, its a pain. That strap makes it easier. Not much room back there for stuff anyway.
Old Feb 25, 2018 | 08:13 AM
  #57
kenny400ex's Avatar
kenny400ex
Originally Posted by Krabill
Was waiting to see one of these threads. The one on the F150 forums site was a fun read. Best thing I did was to get 1 month of amazon prime for free and order all this stuff.
#1 tailgate shock, IMO best mod you can do, under $30 HERE
#2 Toughskins superduty letter inserts under $50 for each set front and rear
#3 unpainted mirror cover caps from ebay HERE and got them painted to match the oxford white, $25 each, gives it the platinum look, ish... either way I like the look.
#4 LED underglow light strips connected to the plugs on each side below the truck. Lights up when opens door then fades out when door closes. Might be a little blingly for some, but you will never loose anything under the truck in the dark.
Plug adapters HERE
the light strips HERE I did use small 3m double sided tape to secure them better than the basic adhesion on the strip, HERE
#5 Rear LED lights hooked to a switch mounted on my hitch (these do not fog up like others I bought and mounted in my grill) HERE
#6 A 40$ switch panel to control all the lights and other things (you all have up fitters so I made downfitters in a little box I custom built to fit in the floor) Panel HERE
#7 a cell phone cradle that clips on my vent from autozone for $10
#8 a remote bass **** to adjust my subwoofer levels on the fly (rest of the stereo was well above 50) HERE
I also have Interior and wheel well lights for under 50 bucks I just don't remember the link I used to get them, they are controlled on the switch and not door activated. Turns out I never use them, maybe next summer on the beach or something.
Here is the above $50 list just to break the thread rules
Coverking kryptek typhoon seat covers
Zone dual steering stabilizer
2.5" lift
35" tires & rockstar rims
bushwhacker flares
12" sundown audio woofer in custom underseat box & rockford p500 amp
weathertech front and rear floor mats (BUY HUSKY INSTEAD, it is impossible to scrub these things clean..)
front window tint @ 20$ (was $75 laser cut and installed)
Some pics of some of the things.
How did you mount your led bars in the grill? Did you have to fabricate some brackets or mounting plates?
Old Feb 25, 2018 | 08:44 AM
  #58
grege's Avatar
grege
Gary
Would you have passed? I'm thinking of getting one.
Old Feb 25, 2018 | 10:13 AM
  #59
Poncho450's Avatar
Poncho450
Actually no, I never hear them at all.
Glad to hear that. Mine will be here tomorrow.
Old Feb 25, 2018 | 10:27 AM
  #60
Platinum18's Avatar
Platinum18
The 5/8 is a perfect fit for the D-rings. I ordered the the 1/4, 5/8, and 3/4. 5/8 is the perfect fit!
