Transmission Stragety
Old Feb 15, 2018 | 11:03 AM
Martin6's Avatar
Martin6
Does anybody know what the transmission stragety is on the 2017 6.7 trucks; specifically torque converter lock up?
  • What gear does the TC lock up at normal acceleration?
  • What gear does the TC lockup at WOT?
  • Is the TC lock up different when the "tow/haul" mode is activated?
  • Is there a difference in lock up when running the transmission in "manual" or if locking out 5th or 6th gear?
Old Feb 15, 2018 | 11:30 AM
UGA33's Avatar
UGA33
The torque converter won't lock up until 3rd gear in normal acceleration. Manual mode will lock it in 2nd. I haven't had a stock programmed truck in a long time to answer any of the other questions. Can't really remember. Lockup won't be affected when you lock out the higher gears (5 or 6).
Old Feb 15, 2018 | 11:40 AM
Buliwyf's Avatar
Buliwyf
My 2015 seems to lock and unlock while remaining in 5th gear in auto. I see an RPM change, without a gear change.
Can't say whether the 17 does, it's too lightly loaded to notice.
Old Feb 15, 2018 | 03:43 PM
Martin6's Avatar
Martin6
Thanks guys. This helps for when I'm towing.
My 2008 was tuned and I had a monitor so it was easy to see when the TC locked up or if it was slipping when under a load.
Old Feb 16, 2018 | 06:26 AM
UGA33's Avatar
UGA33
If you have ForScan, it has the ability to monitor it for you.
trekbasso
27
Jun 12, 2013 11:17 AM
ChunderDownUnder
Feb 2, 2010 06:06 PM
Mark W. Ingalls
Oct 8, 2008 04:49 PM
tholt34
Jan 3, 2007 11:18 PM
bmr906
May 27, 2005 10:00 PM
