torque lock up
Old Sep 16, 2009 | 12:45 AM
ChunderDownUnder's Avatar
ChunderDownUnder
torque lock up
Is there anything I can do to my box to get the torque converter to lock up quicker. I dont want to spend to much on the tranny cause I would rather put my money towards a Allison 6 speed.
Old Sep 16, 2009 | 08:01 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Lock up quicker as in.......
"when it engages, it should do so with less slippage"
OR "it should be commanded to lock up at a lower road speed"
OR "it should engage with a lower accelerator pedal input" ????
Which one of these are you talking about? Only then can there be an answer.
Old Sep 16, 2009 | 09:44 AM
brian42's Avatar
brian42
Veteran: Navy
You can either get a chip or programmer to modify the lockup points or you can manually do it by installing a switch like this one:
http://www.guzzle7pt3.com/tclock.php
Old Sep 16, 2009 | 05:30 PM
alstieg's Avatar
alstieg
My trans felt like it was slipping in every gear and tc not locking in any gear but it was still shifting good. I bought a 6.0 TC and installed it and LOVE the way it locks up and accelerates.
Old Sep 18, 2009 | 05:05 AM
ChunderDownUnder
The lock up just before overdrive is the one Im talking about. My rig takes to long. The revs are high enough but it seems its waiting for a pre determined speed to be obtained before locking up. If Im holding say 2000 rpm I believe it lock up regardless of speed. this things have enough Ka Hoonas to keep on pulling.
Old Sep 18, 2009 | 07:38 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Ok. Ford had a couple of shift strategies that work completely different from one another. My guess is that you have a PCM code in which the torque converter clutch is commanded to apply at roughly 35-40 MPH (56-64 KM/H) in 3rd gear under normal acceleration. Yes, it is a pre-determined speed as you had suspected. The apply point is determined by speed and accelerator pedal position.
Old Sep 18, 2009 | 07:44 AM
ChunderDownUnder
So can anything be done to change this.?????????? I have the Edge programmer running on tow mode and its doesn't change it. Im always waiting for the TC to lock. Its really holding the truck back.
Old Sep 18, 2009 | 12:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You are right, the Evolution does NOTHING to the torque converter clutch apply point for 3rd gear in the "Tow" program (or "Race" for that matter). I know this for a fact because I have the programming and actual Evolution tunes. There are only two ways to do it. First is by installing a switch that grounds the torque converter clutch solenoid windings causing an always-on, forced TCC apply. This way sucks because it is not automatic. You have to remember to turn it on and off. Granted, there are other ways of doing it that are more automatic than a simple switch, but they are not fool proof.
The other way to do it is with custom tuning. Most of my generic heavy towing tunes (pre-live tuning) will lock the TCC at 25 MPH in 2nd gear and just stay locked through the 3rd gear upshift at a minimum upshift speed of 35 MPH. This prevents lugging, high transmission temps, and sluggish acceleration due to an unlocked converter clutch. It can be done with any power level tune as well....it's not isolated to any particular type of tune.
It's probably not what you wanted to hear since programmers are so expensive....but these are the ways around a "late" TCC apply.
Old Feb 2, 2010 | 09:39 AM
Robert6401's Avatar
Robert6401
Do the "Tow" tunes on a chip like DP or PHP lock the TCC sooner? And I'm talking about the chips, not live-tuning.
Old Feb 2, 2010 | 05:25 PM
ChunderDownUnder
Thats what Im hoping. Waiting for my DPF6 to arrive. Wasnt going to do anything to the tranny until I see what the tuner will do.
Old Feb 2, 2010 | 06:06 PM
mexemo's Avatar
mexemo
Will the chip keep the tc locked in deceleration?
thnks
F-250 WARHORSE
35
Oct 16, 2025 08:45 PM
schlepprock250
25
Nov 21, 2015 11:20 PM
Boodrow379
Jul 2, 2015 06:02 AM
onepieceatatime16
Sep 14, 2014 10:47 PM
mdula
Apr 4, 2011 04:12 PM
