Trying to get the pivot arm bolts out so I can change the bushings. I got the nuts off which was the easy part. Seems the bolts may be seized in the bushing sleeve. I have soaked them in liquid wrench and going to let that sit over night. My question is ... can you buy replacement nuts and bolts? I need to know before I start whaling away at those bolts and damage them. The truck is a '77 F-150 2wd
Bolt, axle to mounting flange
5/8"-11 X 3 1/2"
P/N 377179-S2
I couldn't locate any dealer or obsolete supplier that has them but it looks like they're just regular bolts.
I would get grade 5 minimum, preferably GR8.
The nuts (P/N 34981-S4) are listed as a grade 5.
