Radius Arm Bolts
Old Feb 25, 2008 | 10:32 PM
tracert1692's Avatar
tracert1692
Radius Arm Bolts
I recently purchased a '96 F150 4WD and quickly discovered the Radius Arm bushings are shot. I've bought new poly bushings for the truck and plan on grinding off the rivets on the drivers side bracket as suggested in many posts.
I know I need to use grade 8 bolts to replace the old rivets but can any one tell me what bolt size I will need? The posts I've read through mention 7/16 and 1/2 bolts but I was hoping someone could provide a firm answer.
Old Feb 25, 2008 | 10:57 PM
Moore558's Avatar
Moore558
I think it's an either/or situation. I remember on mine I used 7/16 along with the grade 8 lock washers and nuts.
Old Feb 25, 2008 | 11:45 PM
Jonas1022's Avatar
Jonas1022
I recall it's 7/16" also, but wouldn't bet the farm on it. I think that there maybe some play with the 7/16" and none in the 1/2". Any how, I did what he did^^^.
Old Feb 26, 2008 | 12:20 AM
tracert1692
Sounds like the 7/16 bolts have worked for several people so I'm going to give it a shot this weekend. Thank you for the quick responses.
Old Feb 26, 2008 | 06:16 AM
alz's Avatar
alz
If you use the 1/2, you'll need to drill the rivets out with 1/2 drill bit. Use the 7/16.
