Ignition issues
Old Feb 11, 2018 | 09:50 PM
gostephen's Avatar
gostephen
Ignition issues
I am trying to get my truck back on the road
I just did a bunch of work including a new ignition switch and it was running good in till the starter solenoid failed I replaced it
now it will crank over and start but will die as soon as I let go of the key
Old Feb 11, 2018 | 09:52 PM
gostephen's Avatar
gostephen
1975 f250 highboy 390fe c6
Old Feb 11, 2018 | 10:38 PM
meangreen92's Avatar
meangreen92
Might be a bad new ignition switch. How did the solenoid fail? Did it stick closed with the starter 'running away?'
Do you have a ground-strap wire from your engine block to the firewall of the cab?
Old Feb 11, 2018 | 10:56 PM
gostephen's Avatar
gostephen
it ran fine after installing switch
the selonid stopped sending power to the starter
I have a ground wire from the block to cab and an extra from starter to frame
Old Feb 12, 2018 | 07:05 AM
willowbilly3's Avatar
willowbilly3
Do you have a good test light? Simple to trace out circuits with and an exercise in frustration without. 2 feeds to the coil+, one is full 12 volts from the starter relay during cranking and the other is the "run" position through the resistor wire from the switch. It sounds like you have lost power through the "run" circuit.
Old Feb 12, 2018 | 02:56 PM
gostephen's Avatar
gostephen
I will try to do some tests when I get home from work tonight (weather permitting)
Does anyone have a wiring diagram of this circuit
I am wondering if some of the wiring repairs the PO did failed,
Old Feb 13, 2018 | 02:25 PM
gostephen's Avatar
gostephen
I am getting 12v to the coil with engine off key on
Old Feb 13, 2018 | 05:36 PM
gostephen's Avatar
gostephen
I'm leaning to ignition module failed
Old Feb 14, 2018 | 12:35 PM
gostephen's Avatar
gostephen
Problem found wire broke off at back of ignition switch connector
now to figure out how to fix it
Old Feb 14, 2018 | 10:04 PM
gostephen's Avatar
gostephen
Thanks for the ideas problem temporally fixed
I need to find the part number for the connector that plugs into the ignition switch
Now I seem to have developed a wiring problem somewhat in the dash I have smoke coming out of the dash when the ignition is on ( battery is currently disconnected in till I take the dash apart)
john jamieson
Nov 3, 2016 02:47 PM
bayslayer
Dec 5, 2011 04:26 PM
sonofa75
Jun 7, 2007 06:37 PM
wideopen23
Dec 24, 2005 06:58 PM
53Trucker
Sep 26, 2005 10:03 PM
