No start, HOLY CODES BATMAN!!!!!!
when key is first on and fuel pump is charging system I have 70 PSI, as soon as system is charged fuel pressure bleeds off fairly quick. and I don't hear pump comeback on to keep system at 70 psi. could I have a bad pump? my experience is a fuel pump either runs or it doesn't.
Fuel pump should run 20-30 secs with key on, then turns off an won't turn on again until either the truck starts or you cycle the key. It is normal for the pressure to bleed off quickly in most setups without a bunch of check valves, in my experience and reading.
It is *possible* to have a bad pump, but monitoring your fuel pressure while cranking and when it starts/stalls should tell you more about that.
Is your fuel pressure gauge pre or post filter? What filter setup are you running? Is it pre-pump?
I am running out of suggestions here...Once we check these couple of things (hopefully one of them solves your trouble), someone with more knowledge than I will have to jump in- and I'll watch and learn, too
With the stock pump guys are using a 100 micron strainer on the suction side of the pump.
We have checked for the required starting criteria:
1. Minimum values for RPM, ICP, Voltage
2. Fuel (injection event: FIPW, and fuel present: fuel pressure psi)
Once it has enough to start, even temporarily, then we evaluate the logged/video values and see high ICP and some maybe high DC%
Now we are trying to figure out IF those values are a problem (I don't know enough to rule them in or out), and the WHY they are out of range (if that is the case)
So when looking at the WHY, we see the TUNER that controls these and decide to pull it to remove it from the picture.
In the meantime we addressed possible physical failures within a chain...such as injector event. We heated the oil to rule out glowplugs and thicker oil.
We are also wondering if the fuel pressure is dropping off or if the FIPW or something electrical is dropping when he lets off the key from the start position, since it stops immediately.
The ICP isn't dropping drastically during the long cranking, so unlikely a sticking injector is sucking away the oil, causing ICP to crash (not certain yet, but building the case)
The fuel isn't guaranteed to be flowing in the correct volume, maybe?
One of these, I think:
**If ICP falling flat (drops to ~650 in the video when it starts, not sure what to make of that, or if it is tuner strategy or defect?)
**If RPM dying (doesn't look like it, RPM jumps right up with engine jumping to life, so unlikely the problem)
**If electrical dying (why? Conditions: Key transitions from start to run)
**If fuel flow falling off (why? Checked pressure, but what about flow? Injector issues, lines, etc?)
**PCM shutdown (Losing electrical, exceeded some value/parameter and safety shutdown, or tuner?)
**Possible electrical where start position is okay, run position is not (solenoid, grounding, etc?)
**Gross Mechanical Failure (compression, crank, whatever, seems unlikely, no sounds to support, but don't know?)
This is where we are now, unless I missed something?
What is your EOT?
Did you get the fuel lines fixed?
Pressurize the oil rail and listen for leakage under a valve cover.
I'm leaning towards leaking, stuck, failed injector or orings.
The oil side is easy to check with Cody test.
