Speakers
Old Jan 31, 2018 | 06:55 PM
Big Sky's Avatar
Big Sky
Speakers
After owning this beast for the last 14 years its time to upgrade the stereo. I want to order new speakers but on Crutchfield's website it lists different sizes. Are all of the speaker the same size, Front, Middle and Rear?
Old Jan 31, 2018 | 07:26 PM
Jeff53's Avatar
Jeff53
Yes
They're all 4x6, but you can use 5 1/4 or 6 1/2 with adapters.
Old Feb 1, 2018 | 03:16 PM
Magnus E's Avatar
Magnus E
Actually - I believe the originals are 6x8.
Old Feb 1, 2018 | 03:47 PM
Jeff53's Avatar
Jeff53
You're right
Sorry for the misinformation. I knew they were 6X8, since I've already replaced mine, but for some reason typed 4x6.
Old Feb 2, 2018 | 07:16 PM
mojakus's Avatar
mojakus
If it's any help, I recently grabbed some decent inexpensive 6x8s off Amazon: Rockford Fosgate Punch P1683. Bolted right in.
Get some spade connectors and extra wire for the install; I had to snip the factory speaker harness.
Old Feb 2, 2018 | 07:29 PM
Jeff53's Avatar
Jeff53
Adapters
You can buy adapters. Check Crutchfield or Ebay. They plug into the factory harness and you don't have to cut or splice any wires.
Old Feb 3, 2018 | 09:44 AM
mojakus's Avatar
mojakus
further confirmation of my general ineptitude...
I now am fully aware of the Metra 72-5600 Ford Speaker Harness 1998-UP, on Amazon currently for $6.80....
Old Feb 4, 2018 | 12:47 PM
sessland's Avatar
sessland
You can also make your own "adapters" out of wood so you can fit a 6.5" round speaker
Old Feb 4, 2018 | 01:18 PM
Big Sky's Avatar
Big Sky
Those are the ones I'm looking at.
Old Feb 5, 2018 | 10:50 PM
ScaldedDog's Avatar
ScaldedDog
For those who upgraded the speakers, did you do all 6, and did you notice a difference?
Also, how do you get to the back two?
Mark
Old Feb 6, 2018 | 08:37 AM
Jeff53's Avatar
Jeff53
Replacements
I did the 4 doors and left the rear speakers stock for several reasons. I don't have a sub woofer and don't really have plans to install one. So, I get a bit more bass out of the factory paper cone speakers than I do from the aftermarkets, although the aftermarkets seem to have adequate bass for my older ears. I usually only have two people in the vehicle, so the far rear speakers are not a high priority. Also, the rears are a bigger pain in the butt to remove than the door speakers. You have to remove the side panels in the rear, although I believe some people have been able to access the speakers by just loosening the front of the panels and accessing the speakers that way. I honestly don't think you'd notice much difference if you replaced the back speakers. Now, if you're planning on installing a high power amp, I'd probably recommend replacing them as I don't believe the factory speakers are rated for very high wattage.
I'm satisfied with the results of my swap. They're being powered by a Pioneer AVIC X940BT (50W peak, 18W RMS), installed by the previous owner and I think it sounds pretty good. I do think the aftermarket speakers provide a crisper sound with better mid-range and highs, which is to be expected.
Mark
1 Excursion camper
Nov 19, 2013 02:20 PM
VONxRUBENxLA
Nov 27, 2011 08:47 PM
Blondi
Nov 25, 2005 07:20 PM
kodakker
1983 - 2012 Ranger & B-Series
Nov 6, 2004 07:28 AM
Torstein
May 19, 2003 08:19 AM
