? about Electronic Ignition
Old Sep 16, 2003 | 11:57 PM
Putt's Avatar
Putt
You would need to be able to pick up a Duraspark dist. really cheap to beat the cost of the Pertronix kit. It is a very good idea to upgrade your coil with the MSD. It makes the coil work harder, which can overheat a stock and even some aftermarket performance coils. I bought a Blaster coil when I got the MSD, made sense to buy all the ignition from the same manufacturer.
Old Sep 17, 2003 | 08:21 AM
GolferSA's Avatar
GolferSA
I picked up the Pertronix kit and 40,000 volt coil for $90, took maybe an hour to drop it in ... if you can get cheaper and easier than that go for it.
Old Sep 18, 2003 | 06:39 PM
f100guy's Avatar
f100guy
or if any of yall have any newer trucks with tfi you could buy my accel tfi distributor for a 302 for just 60 dollars. it has 10,000 rpm bearings and it looks good.not to mention it works.
Khauler
13
Jan 31, 2011 10:28 PM
Fomoko1
22
Feb 14, 2009 11:35 PM
SLIPSAND
Feb 11, 2004 04:59 PM
Scott_in_Canada
Jun 20, 2003 10:30 PM
waterspots6
Nov 17, 2000 12:29 AM
