tach
Old Nov 15, 2000 | 08:19 PM
waterspots6's Avatar
waterspots6
tach
i have a 1988 ford f-250 4x4 i think it has a eec4 electronic ignition i installed a tech in it from autometer the instructions said not to hook it up to the coil. my questoin is why? what will happen? the instructions said to connect it to the electronic ignition at the tech terminal i could not get the electronic ignition box loose to see were to hook it up to the box i think is located be hind the kick panel on the drivers side can you give me any info. thanks ws6
Old Nov 16, 2000 | 08:41 AM
TallPaul's Avatar
TallPaul
tach
On my 84 F150 the tach terminal was located on a plastic wire connector near the distributor.
Old Nov 16, 2000 | 05:10 PM
cgl's Avatar
cgl
tach
For your truck, which has the TFI Ignition, I pulled this off of the AutoMeter Website.
Ford TFI (thick film integrated)
The green wire from the tach will connect to the green wire with a yellow stripe that is on the coil. This wire may also be either a solid green wire or a green wire with a white stripe.
I have a MSD 6AL on my truck, and it has the Tach Output. But the info above should help you.
Old Nov 17, 2000 | 12:29 AM
lugie's Avatar
lugie
tach
Khauler
13
Jan 31, 2011 10:28 PM
OldgreenF1
Oct 4, 2007 10:07 AM
cajunbull61
Electrical Systems/Wiring
15
Sep 3, 2005 10:25 AM
66 custom cab man
Jun 28, 2005 10:10 AM
tallica2002
Aug 6, 2002 08:44 PM
