? about Electronic Ignition
Old Sep 14, 2003 | 11:15 PM
BigBlueBeast's Avatar
BigBlueBeast
i'm gonna install electronic ignition in my 72 and i was wondering if i should have it professionally done? is it that hard to install?
Old Sep 14, 2003 | 11:51 PM
Mike W's Avatar
Mike W
No, it is easy. I like the msd. You can run it with points and then change to a Duraspark distributer.
Old Sep 14, 2003 | 11:59 PM
Putt's Avatar
Putt
Do you mean an electronic dist. to eliminate points or a capacitive discharge box for higher power? They sre easy to install if you can do a basic tune-up. I agree with Mike W. on the MSD 6 series boxes, they work great! I have a Pertronix Ignitor in the stock dist. in my '66 that I'm happy with.
I had a Mallory Unilite, but it required a special rotor that was a pain to get, the Pertronix uses the stock rotor. Besides the Unilite quit working!! In the winter at about 0* on my lunch hour!
Old Sep 15, 2003 | 09:56 AM
GolferSA's Avatar
GolferSA
I dropped a Pertronix in my original distributor and added the 40,000 volt coil... took maybe an hour, including pulling the distributor and cleaning/buffing it up... piece of cake. I also upgraded the cap to the new larger flat cap (NAPA et al makes an adapter) and 8mm wires... Autolite titanium plugs gapped out to .50 ... BIG improvement!
Old Sep 15, 2003 | 05:43 PM
DesertFE's Avatar
DesertFE
I also put in a Pertronix in my '72 - No more points !! I didn't know there was an adapter for the large flat cap... I may be off to NAPA
Old Sep 15, 2003 | 05:45 PM
Comegetsome's Avatar
Comegetsome
I've been considering the Pertronix for my '67, with a fresh 390. What kind of real world dividends can I expect from this unit, along with a hotter coil and bigger wires?
Old Sep 15, 2003 | 06:50 PM
DuckRyder's Avatar
DuckRyder
The crane conversion is nice as well.
You can do the crane conversion and recurve for about $100.00 and have a rev limiter built in as well.
Benifits are reliability and never having to set or clean points again.
Old Sep 15, 2003 | 07:56 PM
GolferSA's Avatar
GolferSA
Thumbs up ? about Electronic Ignition
https://www.ford-trucks.com/articles/largecap.php
Old Sep 15, 2003 | 08:02 PM
BigBlueBeast
how much difference do they make?
Old Sep 15, 2003 | 09:13 PM
GolferSA's Avatar
GolferSA
I haven't had that much experience with them, just dropped the kit in this past week... but the increased spark has simply got to make it a more efficient fuel burner, and the "no hassle" of no points is well worth it. There's quite a few threads on here, search the Forums... I spent quite a bit of time researching what the FTE experts had to say before I bought mine... needless to say they convinced me. I'll say this much... my 352 fired after about 1/3 of a turn, and the short road test I gave it afterwards it sure seemed a little more spunky.
FYI... the best deals are on eBay, by far. I got the 40,00 volt FlameThrower coil and the Ignitor kit for $90, with free shipping.
Old Sep 15, 2003 | 10:31 PM
MuchToMyDelight's Avatar
MuchToMyDelight
I put the pertronix "ignitor" and an accel super stock coil with autolite platinums gapped at .050, and she fires right up, every time, idles soooo much smoother, and I get about 2 MPG better(a 20% improvement!!)
Old Sep 15, 2003 | 10:48 PM
BigBlueBeast
i was also thinking of a MSD pro billet distrubuter, i looked and i really like some of the flamethrower coils, after this the next thing for the old 390 is a k&n filter, but i am looking forward to installing this,
have any of u had any experiance with the mallory stuff i've heard some ok stuff but havnt had any experiance, o and thanks a ton for the advice and answers
Old Sep 16, 2003 | 08:28 AM
jeremyd72's Avatar
jeremyd72
Question ? about Electronic Ignition
What is the best MSD 6 series to use on my 302 and where is the best place to get one at? Do I hook it up to my duraspark dizzy? Should I use a hotter coil?
Thanks,
Jeremy
Old Sep 16, 2003 | 07:00 PM
Putt's Avatar
Putt
IMO the MSD 6AL is the way to go. Multiple spark and a rev limiter for the future! There is also an adjustable timing control that can be added, it allows up to 15* retard for the occasional bad tank or advance more for premium fuel!
Old Sep 16, 2003 | 09:14 PM
HillbillyHellcat's Avatar
HillbillyHellcat
If you car currently has points, probably the cheapest/easiest way to modernize it is to pick up a reman'd duraspark distributor, drop it in, and wire it directly to a MSD ignition box. An plug in adapter is available also. I have done this to two vehicles and plan to do it to my p/u soon enough!
