Small Stock Side Mirrors
Old Jan 27, 2018 | 05:43 PM
54321toz's Avatar
54321toz
I have small side views on my 84.. I'm sure there are others out there but for the life of me all I've seen on trucks and vans are the large towing type. I was going to replace mine but they seem rare/unique.. Any comments ??? P.S. Canadian Built
Old Jan 27, 2018 | 05:51 PM
Franklin2's Avatar
Franklin2
Yes, they are probably rare and unique because it's hard to see out of them when using the truck with loads that block your vision and you need to back up with the mirrors.
I found out the top two bolt holes that hold those mirrors on match the larger mirrors top bolts, so the little mirrors come off if I have a truck that has them. I then add the two more bolts on the bottom. I just did my ranger, it surprised me the bolt pattern is the same on the little trucks also. The big mirrors fit on it fine.
Old Jan 27, 2018 | 05:57 PM
LARIAT 85's Avatar
LARIAT 85
I have those same mirrors on my [American built] 1985 Lariat. And you're right; you don't see this style very often. I think these *look* better, so I kept them when I restored my truck.
Even though the larger swing-lock style mirrors are obviously more functional, I never really liked how big (DUMBO EARS!) they are and how the lower brace bolts half-way down the door.
Old Jan 27, 2018 | 05:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The left hand mirror was standard equipment, the right hand and all other mirrors were optional.
But none of these mirrors were factory installed. Whatever mirrors were specified, were placed inside the cab at final assembly, as the dealers installed all the outside mirrors.
Pic: See TYPE 5.
Old Jan 27, 2018 | 06:01 PM
Franklin2's Avatar
Franklin2
Type 9 is the one I am most familiar with.
Old Jan 27, 2018 | 06:03 PM
NumberDummy
Low mount "Swing-Lok" mirror. Very popular, first introduced in 1973.
Old Jan 27, 2018 | 06:09 PM
spurredon's Avatar
spurredon
The "swing-lock" feature works great for backing into tight places.
Old Jan 27, 2018 | 08:04 PM
FuzzFace2's Avatar
FuzzFace2
And the type I am going to install on my truck after painting.
I went with this type as the truck will be used as a back up to pull my car trailer and you need good mirrors.
Dave ----
Old Jan 28, 2018 | 03:45 AM
Rembrant's Avatar
Rembrant
My Canadian built '84 F150 has the small mirrors also. I assumed they were common on the bare bones mostly option~less work trucks. I quite like them and prefer them on my truck, but they're really not very functional in my opinion. They do the job, but barely.
I think they have their place. I like the bare bones look and feel of my truck, and the small mirrors suit that. I like being reminded of days gone by when a man could order a truck with the options he wanted, or without the ones he didn't want. (My truck also has no radio, and a kinda like that as well).
Old Jan 28, 2018 | 08:16 AM
ozark1's Avatar
ozark1
Thumbs up
I took the BIG mirrors off my '84..LMC has the small mirrors..and use the same holes that the big ones used..
Old Jan 28, 2018 | 12:26 PM
cadunkle's Avatar
cadunkle
Look at 60s cars, looks like the same type of mirror on my '68 Galaxie. Probably gives you a much better view than the repops of the typical style used on these trucks. If anyone knows a source for mirror glass that doesn't zoom way in giving a narrow and useless field of view I'd love to buy some. Original mirrors had a very wide field of view.
Old Jan 28, 2018 | 01:41 PM
kh0432's Avatar
kh0432
I took the big ones off and put on the small ones. I don’t have a problem seeing because I’m old school and turn my head if I want to change lanes.
Old Jan 28, 2018 | 05:40 PM
headtube's Avatar
headtube
My Canadian built "no options" 83 also has the Type 5 mirrors. I like em!
Old Jan 28, 2018 | 07:16 PM
can0fspam's Avatar
can0fspam
I've got the same ones on my '83 base. They do the job for normal driving although I don't look in them as much as I just turn my head to see behind/around me. They're not good for backing into a spot though (I like being able to see the lines) and I'd imagine they are not sufficient for towing. I kinda prefer the big swingy ones but I don't feel like drilling into the door just to swap them out.
Old Jan 29, 2018 | 12:01 PM
GLR's Avatar
GLR
I picked up an 86 cab in NC , it has the small type 5 mirrors.
dragford1
Jun 26, 2018 07:00 PM
1996_5.8
Sep 18, 2017 03:16 PM
quinletc
Sep 10, 2014 08:30 PM
Dvandy21
Mar 10, 2011 09:24 PM
caseydudem
1997 - 2003 F150
Oct 21, 2008 11:14 AM
