Sponsored by: Real Truck
Charging problems on 2000 7.3
Old Jan 21, 2018 | 08:09 PM
Carcrazzy's Avatar
Carcrazzy
I have a 2000 F350 7.3 I change the alternator and it still won’t charge had the alternator tested and tested fine along with the batteries my connections on the batteries are very clean but when I turn the key on I do not have a battery light that illuminates any help would be greatly appreciated
Old Jan 21, 2018 | 09:02 PM
jetty's Avatar
jetty
In your case the #74 light bulb is probably burnt out. Pulling the instrument panel and changing out the #74 "warning light" bulbs is actually pretty easy. While you are at it you probably want to have some #194LL "gauge illumination" bulbs on hand. Change all the bulbs while you have the instrument panel out. I just went thru this alternator light exercise, posted a wiring diagram at https://www.ford-trucks.com/forums/1...r-reading.html . (I am assuming your diesel only has one alternator). If you have 2 alternators, the PCM gets involved in monitoring the secondary alternator..
To verify the bulb is in fact burnt out, get a multimeter and probe the voltage on the LG/RD wire that makes its connection at the alternator. If it reads anything less than 10VDC your "alternator light" should be "on"; normal alternator operation should provide ~12 VDC at this test point. (the wiring diagram I posted is for a gasser, your diesel wiring is a little different, but the LG/RD wire going to the dash light is exactly the same.)
For what it is worth, I believe our truck Volt Meters are actually controlled by a solid state module, making them more of an "idiot meter" than a Volt Meter.
Old Jan 23, 2018 | 07:30 AM
sunuvabug's Avatar
sunuvabug
Maybe a Bad regulator Wire? Here's What I Did.
Hey CC, here's a link to my problem which although not exactly the same as yours, may hold some insights. Good Luck.
https://www.ford-trucks.com/forums/1...ator-good.html
Jason Rogers
May 5, 2018 08:31 AM
Stewart_H
17
Mar 18, 2016 08:58 PM
Kustomfiend
Electrical Systems/Wiring
Aug 8, 2011 07:31 AM
Eric H
Jan 29, 2009 08:03 PM
79_ford_400_guy
Dec 16, 2003 01:19 PM
