alternator troubles
Old Dec 9, 2003 | 06:04 PM
79_ford_400_guy's Avatar
79_ford_400_guy
alternator troubles
hi i recently put a rebuilt alternator in my truck and it run fine and charged the battery fine and errything........and all a sudden it quit working so i took the alternator back and they gave me a new one...and gave me that regulator thing up by the battery on the fender and yeah i replaced both of them and hooked the alternator up right and everything...still no charge...what else can a guy try...thanks kevin
Old Dec 9, 2003 | 09:38 PM
Crumm's Avatar
Crumm
Did you check all the wiring? You may have a broken wire inside a connector somewhere. Check it all over very closely. It is possible that the new alternator is bad also. Sometimes those rebuilds are not rebuilt with the best of care.
Old Dec 15, 2003 | 02:08 PM
rmcgraw351's Avatar
rmcgraw351
Does the charge light cycle on and off when you turn your ignition key on? if the light bulb is burned out on that light, then your charging system will not work!?! The same if you have a gauge (instead of a light) that fails, it will not send the "excite" signal to your alternator.
Old Dec 15, 2003 | 06:40 PM
FordPickMeUp's Avatar
FordPickMeUp
Do yourself a favor buy a brand new one.thats what i did.
Old Dec 15, 2003 | 07:38 PM
Mike W's Avatar
Mike W
The system will still work if the charge lamp is burned out. There is a resistor across the lamp that will carry current to the alternator field. The ammeter has a shunt.
Check the voltage at the field terminal. If you see around 11, the alternator is bad. If there is no voltage, jumper +12 to the S terminal on the regulator. This will cause it to provide voltage to the field terminal and the alt should start working.
It sounds like a wiring problem. Do you have a light or an ammeter?
Old Dec 16, 2003 | 01:19 PM
ranchero77's Avatar
ranchero77
if the altenator is good and before you try a new altenator check the short adapter connector at the voltage regulator on both ends. these old wires break inside the connector at the terminals. which will sometimes show the alentator to be charging but nothing going to the battery.
LipschitzWrath
22
Aug 14, 2017 05:22 AM
Marty1965
1997 - 2003 F150
Apr 21, 2015 01:31 AM
Tim98TA
Electrical Systems/Wiring
Sep 11, 2013 06:29 AM
Nyxlee
Jan 26, 2011 09:07 AM
zmurphy
Aug 12, 2007 11:01 AM
