Sponsored by: Real Truck
Cheap alternator problems?
Old May 4, 2018 | 11:39 PM
Jason Rogers's Avatar
Jason Rogers
I had a guy replace my alternator around a year ago and the battery light never goes off but i Am getting plenty of voltage. I think it’s just from the cheap alternator he put on there! You guys have any solutions besides replacing it with an oe part?
Old May 5, 2018 | 03:08 AM
seville009's Avatar
seville009
Piece of electrical tape over the light.....
Old May 5, 2018 | 08:23 AM
DogRidesInBack's Avatar
DogRidesInBack
Might be a ground or other loose connection. That may eventually kill the alternator, or maybe it is already damaged. The light could be indicating either or both conditions.
I suggest chasing all connections in the charging circuit including grounds to engine, body, and frame.
But this will take a little more time than taping over the light.
Old May 5, 2018 | 08:31 AM
jetty's Avatar
jetty
Actually quite common problem, alternator working OK & Voltmeter says OK, but the light stays ON. The light is on because the ground leg of the alt light circuit has gone low. Root cause is either a regulator issue or a wiring (most likely ASI connector) issue. https://www.ford-trucks.com/forums/1...r-reading.html
Would closely inspect the ASI connector for a bent/broken pin, else punt this alternator in favor of a new 130 amp unit fr ebay/Amazon.
triskit16
28
Mar 6, 2017 01:21 PM
2danglong
Mar 2, 2011 01:32 PM
79_ford_400_guy
Electrical Systems/Wiring
Dec 16, 2003 01:19 PM
mike
Nov 9, 1999 02:25 AM
