Wiper Blade Chatter
Old Jan 12, 2018 | 05:44 PM
BowtieConvert's Avatar
BowtieConvert
Wiper Blade Chatter
I installed new blades not long ago. I cant remember if they were Bosch or Trico, but they weren't the cheap ones. For some reason, if there isn't sufficient rain or mist to coat the windshield on the down stroke these things stick and "chatter" all the way down. Aside from being annoying as hell it cant be good for the wiper motor either. Any suggestions? Thanks.
Old Jan 12, 2018 | 05:46 PM
stewy604's Avatar
stewy604
Maybe try using a windshield fluid with an additive? I use the Rain-X infused fluid here...works great, and helps the water bead off the window. I also apply the Rain-X coating manually a few times a year. Usually the blades will chatter then they start to dry out.
Old Jan 13, 2018 | 05:32 PM
1956Fatfenders's Avatar
1956Fatfenders
My wipers never chatter, even when I have to use them. I've used Aquapel on every vehicle's windshield I own, and will never go back to Rain-X
Rain Repellent Glass Treatment - Aquapel Glass Treatment
Old Jan 13, 2018 | 05:48 PM
2009kr's Avatar
2009kr
I've found that the Motorcraft wipers (available on Amazon) are the best out there. Try putting a little washer fluid on a paper towel and wipe your blades down - you should do this every few weeks anyway and the OEM wipers will last over a year.
Old Jan 13, 2018 | 09:18 PM
FishOnOne's Avatar
FishOnOne
Agreed... Buy you a set of Motorcraft wipers and forget about them.
Old Jan 13, 2018 | 10:37 PM
HRTKD's Avatar
HRTKD
I use a glass polish/sealant and I don't have any chatter. Water beads up so well on the windshield that I don't have to use the wipers as often.
Old Jan 14, 2018 | 07:53 AM
Poncho450's Avatar
Poncho450
I've been using RainX window cleaner for a while now and have no complaints with the result. But I'm always open to new things for the truck so I ordered a package of 6 Aquapel applicators and a can of Aquapel glass cleaner.
As far as wiper blades, I've always been happy with the blades that have come on my Ford trucks from the factory.
Not so much on this go round. Truck was built in late July 2017 and I bought it 8/28/17. Driver side wiper (go figure) is already leaving streaks across the center of the windshield on a regular basis. Windshield has been cleaned a few times and the blades wiped down with an alcohol pad but relief does not last long.
I just might scoot down to the local NAPA today and see what's in stock for new blades.
Old Jan 14, 2018 | 08:37 AM
Nimrod's Avatar
Nimrod
I will second this..... Works better and lasts longer than rain-x IMHO.
Old Jan 14, 2018 | 10:51 AM
mwheue's Avatar
mwheue
If your truck is less than 6 months old, wipers are free at the dealer. See page 14 in the warrantee manual.
mwillmont
Oct 3, 2017 12:04 PM
Just Strokin
6.7L Power Stroke Diesel
Dec 1, 2016 07:01 AM
mtntop1
Aftermarket Products
13
Feb 17, 2015 09:57 AM
FlaresideF150
Sep 25, 2012 11:26 AM
4inchlovin
Jan 30, 2010 04:33 PM
