Wiper action via Wash Button
Old Nov 29, 2016 | 01:13 PM
Just Strokin's Avatar
Just Strokin
I guess it helps to read the owner's manual sometimes. I never knew two these actions were available. Learned today by accident and then read up about the wipers in the owner's manual. If you already knew it, no comments necessary.
I did not know about the two actions in bold. Is nice to learn them instead of twisting the **** to get a single wipe. Hope it helps someone else.
Copy and paste from 2015 SD Owner's Manual
WINDSHIELD WASHERS
Note: Do not operate the wipers on a dry windshield. This may scratch the glass, damage the wiper blades or cause the wiper motor to burn out. Always use the windshield washer before wiping a dry
windshield.
Note: Do not operate the washers when the washer reservoir is empty. This may cause the washer pump to overheat.
Press the end of the stalk to activate the washer.
• A brief press causes a single wipe without washer fluid.
• A quick press and hold causes the wipers to swipe three times with
washer fluid.
• A long press and hold will activate the wipers and washer fluid for up to 10
seconds.
A wipe will occur a few seconds after washing to clear any remaining washer
fluid. This feature can be turned on and off in the information display.
Old Nov 29, 2016 | 02:55 PM
Specularius's Avatar
Specularius
After using 0000 Steel Wool and rainX on my windshield, that is the most used function for my wipers. A quick press of the button once every 10 minutes or so is all I need to keep the windshield clear.
Old Nov 29, 2016 | 09:53 PM
cangim's Avatar
cangim
Would ya look at that, I too could have used this function the last weekend. Just assumed there wasnt a single wipe and did the twist as with previous trucks. Thanks for sharing
Old Nov 30, 2016 | 07:44 AM
PlayersZ28's Avatar
PlayersZ28
I think every vehicle I've had in the last 10 yrs has had this function
Old Dec 1, 2016 | 07:01 AM
Deuce40s's Avatar
Deuce40s
I learned this same thing about 3 months ago and it's been awesome.
I've always turned the **** once real quick for a single wipe. Now almost every vehicle I get in I can try the same trick and it works. I feel like I've been in the dark for so long, what else am I missing out on?
BowtieConvert
Jan 14, 2018 10:51 AM
RRranch
Feb 6, 2011 05:29 PM
wi_bigfoot
2009 - 2014 F150
Jul 28, 2009 12:54 AM
strokeman
1983 - 2012 Ranger & B-Series
Aug 22, 2006 09:54 PM
IndySilverAnny
1978 - 1996 Big Bronco
Jan 31, 2005 08:45 AM
