Stereo Install Kits?
Old Jan 2, 2018 | 01:35 PM
Pele's Avatar
Pele
Metra Lists three different plastic adapters to install a single DIN aftermarket stereo in the Excursion.
Anyone have any experience with either of them?
Metra Part # 99-5027 | Ford Dash kit | Lincoln Dash kit | Metra Online
  • Allows the radio to be screwed in from the sides rather than using the flimsy metal sleeve
  • Screws to dash using climate control screws
Metra Part # 99-5802 | Ford Dash kit | Lincoln Dash kit | Metra Online
  • Requires metal DIN sleeve from aftermarket radio
  • Snaps into dash bezel
Metra Part # 99-5804 | Ford Dash kit | Lincoln Dash kit | Metra Online
I'm thinking the first one will be the most secure since it uses screws to hold everything together.
Old Jan 17, 2018 | 09:14 PM
bronzefly's Avatar
bronzefly
I'm also looking to upgrade a stock 2000 head unit to something more modern. Did you make a move or does anyone have suggestions?
Old Feb 3, 2018 | 12:45 AM
Bran_SVT's Avatar
Bran_SVT
Bump. I'm interested in upgrading as well.
Old Feb 3, 2018 | 05:57 AM
unleashd's Avatar
unleashd
https://www.ford-trucks.com/forums/1...installed.html
I have documented what I have done in this above referenced post. Details of the head unit and the metra kit are also in that post.
Old Feb 3, 2018 | 08:56 AM
ShelbyHauler's Avatar
ShelbyHauler
I think they are looking for single DIN solutions. Like me, you did a double DIN installation.
Old Feb 3, 2018 | 08:59 AM
unleashd's Avatar
unleashd
Overzealous me
Old Feb 3, 2018 | 01:11 PM
ShelbyHauler
Honestly, I'd go with a more modern Double DIN head over a Single DIN. If you go Single DIN you are only adding another cubby storage slot to your dash. To do a Double DIN you only need to trim the recessed upper and lower lip. The sides remain intact and if you ever want, the Factory radio will still lock in place just like it used to.
Old Feb 3, 2018 | 01:22 PM
ShelbyHauler
Going back and looking at your post, I see we both have the same HU but with Different names Yours is Joying and mine is Eincar.
Old Feb 4, 2018 | 07:21 AM
unleashd's Avatar
unleashd
Pumpkin, Joying, Eincar....different names, same products. Each of them carries a variant of the Android OS, just like on the cell phones
GGerald
May 18, 2020 04:50 AM
Odisvan
17
Oct 9, 2018 09:20 PM
liquidlounge
Sep 25, 2018 07:27 PM
Dan V
May 26, 2016 09:07 PM
berry1234
2004 - 2008 F150
Nov 3, 2013 09:21 PM
