Low fuel pressure warning
Old Dec 31, 2017 | 11:07 AM
  #61
Blwnsmoke's Avatar
Blwnsmoke
Originally Posted by troverman
The place I buy from claims they blend the diesel. It’s been exceptionally cold this last week, and apparently the week ahead. Maybe they aren’t blending enough.
They are either getting their diesel out of Portsmouth, Portland or Boston. I get all my fuel from Boston and there are only 3 brands that sell there. Everyone buys regardless of name brand from one of the 3 there if they get it from Boston.
We start our winter blends in October and haven't had anyone complain yet. And I'll admit, I've yet to run any antigel in my tank.
I'll agree, sounds like a bad tank of fuel.. even though everything is suppose to be sealed, wouldn't be surprised if water front he ground got in. Also, per the State of NH, all of the fill areas are not supposed to have drains in them. Several years back, stations were allowed to have little syphon drains, you'd pull a little chain and the water around the neck of the fill area would drain into the tank. These as of a few years ago were required to be removed and sealed not allowing water to get in.
Depending on the station, it is possible they never did this and during the winter, drop the water in.
Unless there is a breach in the tanker truck, typically if one station gets bad fuel, it will be bad across many because it comes from the same port.
Old Dec 31, 2017 | 01:24 PM
  #62
troverman's Avatar
troverman
I usually buy my fuel from Cumberland Farms...brand new station in my town. Alternately, I use Citgo.
Old Dec 31, 2017 | 02:12 PM
  #63
HouseMouse's Avatar
HouseMouse
Go with Citgo. Cumberland Farms...... Stick with Citgo.
Old Dec 31, 2017 | 03:46 PM
  #64
2009kr's Avatar
2009kr
I must be doing something wrong. Only -14F this morning and she froze up again. Started, but low fuel pressure and reduced power and check engine light. Tried to drive and she won’t do anything but creep and stall. Tank has a lot of Ford anti-gel in it.
I've read that both the pm23 and fuel need to be above freezing for the anti-gel chemical reaction to occur properly. If you keep the pm23 above freezing and add it right when filling from an underground tank, it should work.
Old Dec 31, 2017 | 03:54 PM
  #65
troverman's Avatar
troverman
Thank you 2009kr. You are exactly right...says so right on the bottle. I got the truck running and up to my heated shop where it fits (won’t fit in my garage). I am leaving it there for 3 or 4 hours and then will add warm pm23 and take for a drive.
Old Dec 31, 2017 | 04:01 PM
  #66
Blwnsmoke's Avatar
Blwnsmoke
I'd drain a few ounces out of your separator as well.
Old Dec 31, 2017 | 04:02 PM
  #67
Blwnsmoke's Avatar
Blwnsmoke
There is nothing wrong with Cumberland Farms. And Citgo.. their gas isn't Citgo branded. The Citgo stations just like any other station buy from whatever is cheapest at the port at that particular day/time.
Old Dec 31, 2017 | 04:03 PM
  #68
troverman's Avatar
troverman
I’ve had nothing but good luck with Cumbys diesel, definitely a high-volume station. City DPW is filling there now too. But I’ve heard negative things about Cumberland Farms gas, especially when it was labeled Gulf.
Old Dec 31, 2017 | 04:06 PM
  #69
troverman's Avatar
troverman
Thanks, I will.
Old Dec 31, 2017 | 07:00 PM
  #70
HouseMouse's Avatar
HouseMouse
Just my thoughts..... If someone were on the road traveling cross country during the winter months as in like, right now.... How is one going to get their truck heated up in a heated environment just to get the diesel fuel and PM23 warmed up?
Old Dec 31, 2017 | 07:49 PM
  #71
Blwnsmoke's Avatar
Blwnsmoke
Well 2 scenarios that I can think of. I keep my PM23 in my truck so it is warm (dump it in when fueling up). And the fuel in the ground is typically high 40s to mid 50s depending on the time of year. So above freezing fuel going into the tank with cab warm PM23 being dumped in.
Old Dec 31, 2017 | 07:52 PM
  #72
HouseMouse's Avatar
HouseMouse
Some Towns, Municipalities and Farm operations.... Have above storage tanks. There are still Gas Stations out there with above ground storage tanks in operation also.
Old Dec 31, 2017 | 08:07 PM
  #73
Brandon606's Avatar
Brandon606
I thought there was a fuel warmer/cooler? Wouldnt this make the fuel on the return line to the tank keeping the tank fuel somewhat warm? If so wouldnt that debunk all theories on the Additive mixing, maybe I misunderstood the warmer/cooler thing...
Old Dec 31, 2017 | 08:56 PM
  #74
oak's Avatar
oak
This is from page 178 of my manual regarding the fuel warmer.
Your vehicle has a fuel and water separator
that recirculates fuel from the engine to
help prevent fuel filter clogging. To avoid
engine fuel starvation during cold weather
operation of 32°F (0°C) or below, we
recommend that the fuel level in your tank
should not drop below 1⁄4 full. This helps
prevent air from entering the fuel system
and stalling the engine.
Old Dec 31, 2017 | 10:54 PM
  #75
bushpilot's Avatar
bushpilot
subscribing - will be making a 19 hr run from Virginia to Houston in the morning - is 8* (in virginia now) and its not gonna get much above 3 until we're home
