question about torque converter
Old Dec 26, 2017 | 12:59 PM
lakequ's Avatar
lakequ
this is probably a stupid question but how does the tc get fluid does it pump from the trans or does it get filled separate thanks for the help in advance
Old Dec 26, 2017 | 01:10 PM
mrollings53's Avatar
mrollings53
The transmission pump fills it, but it should be filled by hand if installing a new, or empty one to limit wear.
Old Dec 26, 2017 | 01:23 PM
lakequ's Avatar
lakequ
well i just swapped a trans in to my 97 and i filled the torque converter until it started to pour out and i just finished the swap and started up the truck and the tc is making a rattling noise and it is leaking some fluid. does this mean the tc is bad?
Old Dec 26, 2017 | 02:53 PM
lakequ's Avatar
lakequ
i think i fixed the leaking problem but the tc still rattles should i let it run to see if it will fill the tc more??
Old Dec 26, 2017 | 03:46 PM
rla2005's Avatar
rla2005
How much total fluid have you put in?
Have you checked the fluid level via the dipstick?
Old Dec 26, 2017 | 03:54 PM
lakequ's Avatar
lakequ
i put in toatal about 16 quarts and it read full on the dip stick befor some leaked out now its just right below full. im going to get more fluid and fill it back up. and it only leaked when it was running was that the torque converter?
Old Dec 26, 2017 | 04:26 PM
rla2005's Avatar
rla2005
16 qts. looks about right for an E4OD. Without being there in person the noise is very difficult to diagnose.
Old Dec 26, 2017 | 06:37 PM
z31freakify's Avatar
z31freakify
Did you tighten the TC bolts holding the flex plate? Did you visually inspect the flex plate for damage?
Old Dec 27, 2017 | 09:02 AM
lakequ's Avatar
lakequ
yes the flex plate is fine and is bolted tight but im going to go over everything today to make sure everything is tight. thanks for the help if it still does it after i check everything i will try to take a video and post it here
Old Dec 27, 2017 | 03:58 PM
lakequ's Avatar
lakequ
ok so i think i found my problem i thought i had all the bolts holding the trans to the motor were tight but the trans must not have been perfectly lined up so after starting it up the trans must have shifted and now the bolts are just a little loose so i will see if tightening up the bolts fixes it. its too cold to work on it today and i ran out of propane for the heater
jbravata2
Nov 20, 2014 07:05 PM
djmichael24951
Apr 5, 2014 04:35 PM
Franko72
Oct 13, 2009 06:49 PM
Dmax Stroked 00
21
Oct 21, 2008 02:56 PM
2FordTrucks
May 8, 2003 12:05 AM
