6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Egr valve
Old Dec 24, 2017 | 07:43 AM
Williams65's Avatar
Williams65
Egr valve
I am new to this forum as well as diesels. I asked this question in a nother theead but figured i woukd start another one. I have a torque tech tuner that disables the egr. Does it disable the valve in the open or closed position, and would it be better if i went ahead and removed it and the coolers completely?
Old Dec 24, 2017 | 09:31 AM
Copper.Farm's Avatar
Copper.Farm
Keep doing research as you enter the up and coming sport of off-road diesel racing.
Most tuners will disable the EGR to the closed position, you can validate that from the manufacturers website or be contacting the manufacturer if they are still in business.
There are plenty of companies selling blocking plates in support of removing the EGR coolers, all in support of off-road diesel racing.
Old Dec 28, 2017 | 08:34 PM
Picton's Avatar
Picton
Copper describes this process brilliantly.
Old Dec 29, 2017 | 08:23 AM
Firefighter 1406's Avatar
Firefighter 1406
I am no expert. But from what I have read I would suggest deleting everything. Even with the coolers not getting exhaust through them they can still leak. Most troubles that I have read about are best dealt with a full delete. Not saying you can’t still have issues. Just giving my humble opinion.
Old Dec 29, 2017 | 09:48 AM
Williams65's Avatar
Williams65
Yes I was thinking the same thing, my only concern was that I've read a few guys having problems with the crossover pipe starting to leak because it's no longer supported by the EGR coolers and their mountings. I guess they are developing leaks where it is welded to the up pipe?
Old Dec 29, 2017 | 10:08 AM
sxrfun's Avatar
sxrfun
I installed black off plate and left egr coolers in place for this reason....to support the crossover pipe. That was 4 years ago and no problems.
Old Dec 29, 2017 | 10:09 AM
sxrfun's Avatar
sxrfun
Ok...that and I was just to lazy to go through the whole delete haha.
Old Dec 31, 2017 | 09:42 PM
Picton's Avatar
Picton
Sounds like I may be going that route. I mean...if the block off plates are quality and bolt up correctly...even of the coolers started to leak, coolant shouldn't make it into the engine. AND...you still have that support for the crossover pipe.
What block-off kit did you use?
Old Jan 1, 2018 | 10:23 AM
sxrfun's Avatar
sxrfun
Hmm...can't quite recall what kit i used.
Some advice I would give though.....have extra gaskets on hand just in case....When I pried the joint apart between the lower EGR cooler and the crossover pipe I damaged the gasket....and you guess it....I didn't have an extra on hand.
Old Jan 1, 2018 | 10:46 AM
73F700's Avatar
73F700
I cut my own, angle grinder and 1/8" steel. Unbolt the top and remove the gasket - use the gasket as a template. Perhaps not up to your description of 'quality' but in my opinion, if the coolant leaks in the coolers it is not going to get around a flat plate and back into the egr pipe... trick is be sure that the plate is thick enough to take the heat.
For the record some have had trouble with the ebp sensor freezing if they use a block off kit - shouldn't be a problem in Texas
Old Jan 1, 2018 | 11:09 AM
sxrfun's Avatar
sxrfun
That works to....:-). Only problems I've heard with EBP sensor freezing is when you remove the EGR coolers completely. Removing the coolers removes a heat source near the ebp sensor that keeps it from freezing.
On a side note....73F700, we're both from Ontario....where abouts?
Old Jan 1, 2018 | 11:27 AM
73F700's Avatar
73F700
Perth - between Kingston and Ottawa
Old Jan 1, 2018 | 05:10 PM
sxrfun's Avatar
sxrfun
Ahh cool..been out that way many times....Just north of Toronto here...
kornfanjoe
Apr 4, 2012 07:03 PM
Cheapteen979
16
Jan 5, 2012 05:47 AM
caiati
Jan 2, 2012 07:31 AM
F250BlackChrome
Jul 14, 2011 11:08 AM
Fluid Power
May 30, 2007 12:32 AM
