Sponsored by: Auxito
Blinker, Brake Light and Reverse Light Problem.
Old Dec 21, 2017 | 12:18 PM
Allan James Enns's Avatar
Allan James Enns
New Poster, Searched the FAQ and Advanced searches to no avail. 1997 f150, 4x4, 4.6L 320,000km. With headlights lights off, turn signal blinks faster when applying brakes. With headlights lights on, turn signal blinks faster all the time(without applying brakes). Brake lights not working, Reverse lights not working, Brake light on top of cab working. Several weeks ago, thought it might be the brake light switch(the one attached to the brake peddle) Removed switch, reinstalled same switch, Walla, everything working. Thought it was a bad switch or bad contact. Two weeks later, same problem, replace brake switch with a new one, no difference, still not working. In the process of changing the switch one of the power wires to the switch broke. Repaired wire, can start vehicle again, everything else not working as described above. Have checked fuses and bulbs. Looks good. 4 way flashers work. Tested the steering wheel in several positions, does not seem to make a difference.
Old Dec 21, 2017 | 12:36 PM
dieselss's Avatar
dieselss
Have you checked the ground for all the lights .
it's on the frame by the spare
Old Dec 21, 2017 | 02:56 PM
Allan James Enns
I'll have a look.
Old Dec 21, 2017 | 03:31 PM
Allan James Enns
Thank you. Everything looks good back there, but after fiddling with the wiring everything seems to be working again. I do recall that we fiddled around in the back there the first time too, and everything worked after that as well. I did not find the break or loose connection but pretty sure the problem is in the back end wiring somewhere. We are too cold to be pulling on wires outdoors right now, so we'll tackle this when it warms up.
Old Dec 21, 2017 | 08:26 PM
steve(ill)'s Avatar
steve(ill)
the wire may not be broken.. it may be corroded or the grounded attachment rusted which is changing the resistance in the system.
Old Dec 22, 2017 | 02:42 PM
Allan James Enns
Thanks Steve, I found one of the wires that goes to the licence plate light bulb was broken off and exposed wire dangling against the frame. I removed it. Don't know if that was the issue but will run for a while and see what happens, it was working today. If problems persist, I will go after that ground wire. Seem well secured but it was packed in moist dirt which could cause corrosion as you say.
columbia1spring
Apr 20, 2018 12:44 PM
cdouglas75
Jul 23, 2015 08:55 AM
pittdog1977
Jun 3, 2014 09:53 AM
alexd52492
1983 - 2012 Ranger & B-Series
Aug 23, 2012 02:54 AM
gman150
Electrical Systems/Wiring
Oct 8, 2004 08:38 AM
