2000 F150 4.6 V8 - Ford Truck Enthusiasts Forums
2000 F150 4.6 V8
Old 12-07-2017, 04:34 PM
WD Ray WD Ray is offline
WD Ray is starting off with a positive reputation.
2000 F150 4.6 V8
I need your advice. Put yourself in my shoes. If you just bought a excellent running used 2000 F150 4.6 V8 ,4x2 ,auto trans, what are all of the things you would do in regards to maint. , not knowing anything about its previous maint records? From most important to do's to the least important to do's?
Keep in mind the trucks runs excellent,but being that most of us on here are somewhat obsessed with doing things to our trucks.
Old 12-08-2017, 12:02 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Does it have a safety check before you bought it? If not;
Oil change if it's dirty.
Brake lining/pad/rotor check; park brake cable check holding and release
All suspension and steering check
Body and frame structural check for rust
Check one sparkplug for wear and gap. Change if necessary
Antifreeze check for -35*F and acidity.
Year of battery; life usually 5-7 years
All lighting, horn, signals, brake, reverse, etc.
Trans fluid check and change filter
Pwr Strg fluid check
Look for leaks from diff, trans, eng, rad, brakes and strg.
Check when key turned On all tell-tale lights work, ie. check engine, park brake, abs, oil, coollant, brake, seat belt, etc.
Just some of the things I can think of if not safetied.
Old 12-08-2017, 09:03 AM
Sam I Am's Avatar
Sam I Am Sam I Am is online now
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
radiator & heater hoses
vacuum hoses
accessory drive belt
PCV valve and hoses
clean MAF, IAC, EGR, throttle body
Should I keep it, or ditch it while I can...? hunter12 6.4L Power Stroke Diesel 5 03-16-2017 05:04 PM
Preventative Maint erickz 1968-2013 Full Size Vans 15 03-09-2017 01:46 AM
6.0 guy now in 7.3: What else to upgrade? JIMRSX 1999 - 2003 7.3L Power Stroke Diesel 15 02-15-2017 03:33 PM
08 escape recommended maint BBsound Escape & Escape Hybrid 1 12-11-2016 12:57 AM
New 2005 Excursion unsure about maint. history Singlecoil 6.0L Power Stroke Diesel 9 10-20-2016 07:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
