Clunking noise
Old Dec 17, 2017 | 10:36 AM
johnsonjf's Avatar
johnsonjf
Clunking noise
Good morning,
I have a 2004 Excursion 4x4 with a 6.0 PSD. I’ve replaced all the ball joints and steering components, sway bar links are also new (on the front), made sure everything is tight. I am starting to hear a clunking noise when I go over bumps, the noise is coming from the front and back. I am thinking it could be the leaf springs in their shackles wearing out the bushings. Any thoughts on this? I’ve looked into replacing all of the bushings this week.
Thanks,
Jeff
Old Dec 17, 2017 | 10:43 AM
A Rodder's Avatar
A Rodder
Possibly spring ends rubbing on the shackles or body mounts.
Old Dec 17, 2017 | 11:36 AM
fordboy67's Avatar
fordboy67
I see you said sway bar links are new, how bout the sway bar bushings? I had a pretty loud clunk that replacing these took care of even though visually they looked ok. Just a thought! Good luck!
Old Dec 17, 2017 | 11:48 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Jeff, you are on the right track. I have same issue, and I just upgraded rear springs and bushings recently (mod B springs with Energy Suspension bushings). Clunk in the rear is now gone, and I only have the clunk-in-the-front left. Front axle and leaf springs will be gone soon, so that should be resolved then.
Old Dec 17, 2017 | 03:12 PM
johnsonjf's Avatar
johnsonjf
I’ve been looking at different bushing sets. Is there a difference between the black, blue or red Energy Suspension bushings? Looking at blue Moog sway bar bushings. If the weather will cooperate I hope to have all of them in on Wednesday.
Thanks
Jeff
Old Dec 17, 2017 | 06:05 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I went with red. I think they are all poly material regardless of color if buying from Energy.
Old Dec 21, 2017 | 05:50 PM
johnsonjf's Avatar
johnsonjf
What a job from hell. Replaced the first leaf spring bushing on the front, took 2 hours to get the old one out. There has to be an easier way than using a drill and hammer, any suggestions? I also replaced the front sway bar bushings, those were simple.
Jeff
Old Dec 21, 2017 | 06:32 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I posted how I did it in detail in the spring mod thread last month...or the month before. It is all running together for me here lately.
Found it:
Page 3106 post 46,584 of the "What did you do to your X today" thread...
Big ball joint C clamp...2" socket....drill bits...hammer....air hammer/chisel. Went quick for me. Keep reading over to page 3107.
Old Dec 22, 2017 | 04:04 AM
Watcher58's Avatar
Watcher58
Front is probably the body mount ( aka Ford Part No.: 2C7Z-1000154-AA
Insulator ) in the #2 position. Ford conveniently discontinued the upper part but you can still get the lower which is absolutely ludicrous. These are the only 2 insulator parts (LH and RH) I see that are discontinued. Strange how they no longer make the crappy one.
elementbeer
Dec 10, 2009 08:58 AM
myblkex
Apr 2, 2009 06:27 PM
mykels
Dec 9, 2008 06:43 AM
devink
Sep 29, 2008 07:38 AM
DD1684
Jan 3, 2008 08:44 PM
