Greasing the front suspension ?
Old Mar 25, 2009 | 05:46 PM
myblkex's Avatar
myblkex
My Ex is making a creaking noise from the front passenger sidewhen it goes up and down - I think it probably is time for bushings in the front springs - but wondering is there anything that can be greased etc... ?
Old Mar 25, 2009 | 07:24 PM
BAJI26's Avatar
BAJI26
Mine also but couldn't locate it. There's also a squeak in the rear.
Old Mar 26, 2009 | 01:23 PM
luxury's Avatar
luxury
It's probably the ball joints. If they're original, they're not greasable. Could also be the sway bar bushings - try shooting some silicone or WD-40 between the bar and the rubber bushing.
Old Mar 26, 2009 | 02:29 PM
YellowSled's Avatar
YellowSled
mine creaks from the front pass area also.. wierd...
Old Mar 29, 2009 | 06:52 PM
beachcomer1962's Avatar
beachcomer1962
Mine too has a creaking in the rear.Keep us informed
Old Apr 2, 2009 | 05:39 PM
myblkex's Avatar
myblkex
Update -- I figured I'd at least try spraying the passenger side leaf spring shackle and hanger bushings with a quick shot of Silicone Spray Lube and give it a shot. It's now been about 100 miles of city and hwy driving and the creaking seems to have gone away completely... We'll wait and see now for how long. Probably would be best to just change out the bushings - but for now if this works...
Old Apr 2, 2009 | 06:27 PM
1's Avatar
I was gonna suggest going for the leaf spring eyes as well, I'd even give some white lithium grease in a spray can a shot. I think either would work, but my first choice would be teh silicone as it would probably resist washing away better. The noise will liekly return after a while, and a new bushing is probably in order, you can get em replaced fairly cheap if you go to a spring shop usually.
