6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
PO 196??
Old Dec 15, 2017 | 12:26 PM
Firefighter 1406's Avatar
Firefighter 1406
PO 196??
Started the truck with the remote start this morning. Was 22 degrees this morning and truck had been plugged in all night. Ran for 10 min before I came out and I had a check engine light on. Ran the codes through my SCT Livewire and saw PO 196. I searched on here and the web. Anybody have any insight on this?
Old Dec 15, 2017 | 03:42 PM
slowmans's Avatar
slowmans
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
I would be willing to bet it was because the ruck was plugged in and the difference in the oil/coolant temp was different.
Found this online:
Description:
This error occurs if time required for EOT to warm up to
50º C is greater than the specified value or the EOT does
not change by at least 2 degrees from the value stored
in KAM, followed with the engine running off low idle.
Software parameters required to set code:
EOT dependant
20minutes of engine running and EOT
has not changed more than 5 deg C
Old Dec 15, 2017 | 04:01 PM
Firefighter 1406
Found this online:
Description:
EOT dependant
Weird. Thank you for the info. So you mean that all winter long I am gonna get this code probably? I always plug in the truck.
Old Dec 15, 2017 | 04:17 PM
slowmans's Avatar
slowmans
I honestly don't know? i have never plugged my truck in and have never seen the code.
Old Dec 15, 2017 | 07:08 PM
Firefighter 1406
Interesting. I hope that’s all it is. I couldn’t even find any info on it at all.
Old Dec 20, 2017 | 01:06 PM
speakerfritz's Avatar
speakerfritz
what weather temps are we talking about and what weight oil are you using?
"¾ To ensure optimum cold weather starting performance, and improve cabin heating, the 120 volt engine block heater should be
used during any cold weather operation. The engine block heater is required when the vehicle is to be started at temperatures
below -10F (-23C).
Old Dec 20, 2017 | 03:19 PM
sxrfun's Avatar
sxrfun
I plug my truck in all the time. When at work it's plugged in all night at the station from 9pm till i leave around 7 am....I've never had this code.
Old Dec 21, 2017 | 06:35 AM
Firefighter 1406
below -10F (-23C).
It was 15-20 degrees when started. Had been plugged in all night. I am running Delo 5W40 Full Synthetic. It’s habit from my 7.3 , I always plug in the truck. Figure any amount of heat I can get in the engine before startup the better.
I am wondering if it was a fluke. I haven’t had the code again..............so far that is.
Old Mar 5, 2020 | 09:45 PM
Trent Tackitt's Avatar
Trent Tackitt
I plug my truck in every night and I get this code every now and then 🤷🏼‍♂️ It would make sense about plugging your truck in because if your oil and coolant get too far away on temp it’ll throw the code
Farmboypowerstroke
Sep 27, 2010 11:24 AM
funzjb1
Feb 19, 2010 09:49 PM
PDX_Doug
Dec 23, 2008 10:56 AM
gov2mod
Nov 15, 2004 11:41 PM
