Ford Truck Enthusiasts Forums
-   6.4L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum169/)
-   -   PO 196?? (https://www.ford-trucks.com/forums/1520069-po-196-a.html)
Firefighter 1406 12-15-2017 12:26 PM
PO 196??
Started the truck with the remote start this morning. Was 22 degrees this morning and truck had been plugged in all night. Ran for 10 min before I came out and I had a check engine light on. Ran the codes through my SCT Livewire and saw PO 196. I searched on here and the web. Anybody have any insight on this?
slowmans 12-15-2017 03:42 PM
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
I would be willing to bet it was because the ruck was plugged in and the difference in the oil/coolant temp was different.
Found this online:
Description:
This error occurs if time required for EOT to warm up to
50 C is greater than the specified value or the EOT does
not change by at least 2 degrees from the value stored
in KAM, followed with the engine running off low idle.
Software parameters required to set code:
EOT dependant
20minutes of engine running and EOT
has not changed more than 5 deg C
Firefighter 1406 12-15-2017 04:01 PM
Found this online:
Description:
EOT dependant
Weird. Thank you for the info. So you mean that all winter long I am gonna get this code probably? I always plug in the truck.
slowmans 12-15-2017 04:17 PM
I honestly don't know? i have never plugged my truck in and have never seen the code.
Firefighter 1406 12-15-2017 07:08 PM
Interesting. I hope that’s all it is. I couldn’t even find any info on it at all.
speakerfritz 12-20-2017 01:06 PM
what weather temps are we talking about and what weight oil are you using?
" To ensure optimum cold weather starting performance, and improve cabin heating, the 120 volt engine block heater should be
used during any cold weather operation. The engine block heater is required when the vehicle is to be started at temperatures
below -10F (-23C).
sxrfun 12-20-2017 03:19 PM
I plug my truck in all the time. When at work it's plugged in all night at the station from 9pm till i leave around 7 am....I've never had this code.
Firefighter 1406 12-21-2017 06:35 AM
below -10F (-23C).
It was 15-20 degrees when started. Had been plugged in all night. I am running Delo 5W40 Full Synthetic. It’s habit from my 7.3 , I always plug in the truck. Figure any amount of heat I can get in the engine before startup the better.
I am wondering if it was a fluke. I haven’t had the code again..............so far that is.
