Have code, need to know what it means
Sep 27, 2010 | 10:14 AM
P1184 Engine Oil Tamp Sensor Circuit Performance
What does it mean, and what do i have to replace?
Thanks
Sep 27, 2010 | 10:34 AM
DB9 DIAGNOSTIC TROUBLE CODE (DTC) OR P1184
DTC P1184 indicates that the engine oil temperature is not warm enough to perform a KOER Cylinder Contribution Self Test. The engine oil temperature must be greater than 20°C or 68°F (3.82 volts).
Possible causes:
engine not fully warmed up
low oil level
cooling system failure
worn or damaged EOT sensor
faulty thermostat
EOT sensor circuit failure
Sep 27, 2010 | 10:38 AM
What are you checking the codes with? Can you read the EOT temp?
Sep 27, 2010 | 11:14 AM
Quote:
Originally Posted by
mueckster
Yes I can check the EOT
Sep 27, 2010 | 11:16 AM
Was the engine warmed up when it set the code? Were you running the CCT on it when you got the code? Clear it and see if it returns.
Sep 27, 2010 | 11:17 AM
I have 2 or three injectors that doesn't pass buzz test, and the same for the cc test, but the truck runs fine
Sep 27, 2010 | 11:18 AM
Are the injectors #3 and #8?
Sep 27, 2010 | 11:19 AM
Gotta run. But I will try to help you figure this later if you haven't already.
Sep 27, 2010 | 11:24 AM
miller_feed
1,2 says Contribution/balance fault
gsxr1300
6.7L Power Stroke Diesel
Aug 12, 2012 05:43 PM
FONRDAY
Apr 6, 2012 09:11 AM
spr1516
Oct 9, 2008 08:30 AM
dhglaser
Jul 30, 2003 10:50 AM
jherman
18
Nov 26, 2002 03:11 PM
2005 ,
2006 ,
circuit ,
code ,
codes ,
engine ,
eot ,
expedition ,
f150 ,
f250 ,
ford ,
mean ,
p1184 ,
performance ,
trouble
