Installing Remote Keyless Entry
Old Dec 22, 2020 | 10:53 AM
  #31
1992 f250 fummins's Avatar
1992 f250 fummins
Originally Posted by droppedf100
That’s weird. I swapped my truck from an obd2 96 to a obd1 95 and in the process I found the truck had factory rke. I ended up swapping every single harness under the hood and inside the cab and I had no problems. But before I swapped the power window/lock/mirror harness I checked and it had the ground and 12v reversed I believe. I borrowed the book from a friend but you can find them on eBay
Is the harness under the hood different? I still have my starting/charging system, head lights, running lights ect. Only thing i have noticed is now that i started the truck, im now able to use the LOCK button to lock the doors but not unlock, and every time i hit the lock/unlock button it will power my running lights as long as i hold the button either way.
Old Dec 22, 2020 | 01:56 PM
  #32
droppedf100's Avatar
droppedf100
The under hood has nothing to do with it. I swapped everything so I could install a Stinger PimpXShift ecu. I’m no expert but I didn’t have any problems once I swapped all of the interior harnesses
Capt.Schenk
Jan 18, 2008 10:50 AM
kl67
May 1, 2005 07:41 PM
gypsyrose31299
Jun 2, 2004 10:04 PM
NCF150
1997 - 2003 F150
Jan 17, 2004 10:20 PM
fiveinarow
Nov 18, 2003 01:39 PM
