Adding Entry Keypad
Old Jan 17, 2008 | 10:54 PM
Capt.Schenk's Avatar
Capt.Schenk
Adding Entry Keypad
I want to add a "keyless entry keypad" on my door. I don't have the "keyless entry" or factory alarm on my truck, so I can't use the wireless keypad everyone's selling. I finally found a "wired" keypad for sale, but now I need the wiring harness for it. Anyone know the easiest way of doing this? What does it wire to? The actuator or the L/U switch?
Old Jan 17, 2008 | 11:07 PM
empiretc's Avatar
empiretc
It wires to unlock switch. You just need to connect to power, ground, and the switch. But that depends if the one you are looking at uses batteries or not. It's pretty straight forward.
Old Jan 17, 2008 | 11:17 PM
Capt.Schenk
Ok, well, I think I'm going to go ahead and buy the keypad and start looking for the wiring harness tomorrow. If anyone happens to know the part #, PLEASE feel free to share it with me
Old Jan 18, 2008 | 02:38 AM
griff64's Avatar
griff64
Capt.Schenk
Junior User Join Date: Sep 2007
Adding Entry Keypad
Hi, i have a remote start/alarm on my truck and love it, i think they are only about 300 installed. might want to look at that as an option. just a little info!!! Dave
Old Jan 18, 2008 | 08:02 AM
Capt.Schenk
Thanks for the sug., griff. What I'm doing is installing a keyless/alarm system and new door handles without locks. I plan on using my alarm to gain entry into the truck, but I want to add the keypad just in case I lose the remotes for the alarm. I have the 6-spd manual, so I didn't want to mess with the remote start. I'm also adding remote battery terminals just in case the batteries go dead. Any one have a suggestion on where to install the remote terminals?
Old Jan 18, 2008 | 08:12 AM
empiretc's Avatar
empiretc
If you are going to so that, then buy a wireless keypad that you can program. They can be had for ~$50. You will need to find one that is compatible with the alarm you are getting, though. Most alarms disable the factory FOB when armed.
Old Jan 18, 2008 | 10:50 AM
griff64's Avatar
griff64
hi, my Dad's 50 Olds has shaved handles and he put some aux. posts under fenderwell near bat. connect them to the bat Dave
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
kwhite
2009 - 2014 F150
Feb 9, 2010 10:17 PM
crownvic
Feb 19, 2008 08:08 PM
excursion2001
General Automotive Discussion
Feb 9, 2004 10:10 AM
