Installing Remote Keyless Entry
Old Dec 7, 2017 | 08:57 AM
Nathan7.3's Avatar
Nathan7.3
My locks are all ready starting to freeze so I want to add keyless entry. Mt truck is a 1995 f250 XLT and I do not have the RKE module on my truck. I've researching this and can't find the answer, so can I go to the junk yard and take the model off another truck and plug it all into my truck. Or does it require a lot of cutting and splicing to install a factory ford system.
If it does require a lot of work, then would I bet better off with trying to install a after market system or would that be the same amount of work. I'm no professional so I would like to go with the simplest and most reliable route. Let me know your experiences.
Old Dec 7, 2017 | 11:45 AM
mrollings53's Avatar
mrollings53
A Ford RKE module needs the wiring harness it's attached to to work properly. Your old harness can have the RKE elements spliced in, but it is a thousand times easier to just use the RKE harness.
Old Dec 7, 2017 | 02:32 PM
Freightrain's Avatar
Freightrain
The hard part of putting aftemarket keyless in there trucks is getting to the harness in the kick panel.
I put remote start in mine but gave up on the keyless part. These trucks have this big aluminum casting that covers over the kick panel area and you can hardly get to the wiring harness to cut into and hook up.
I've heard some guys go into the rubber boot that holds the wires going to the door. I don't want to do it that way. My '89 was no problem. My '95 is completely different under there.
I've heard the horror of trying to add the factory harness.
Old Dec 7, 2017 | 02:51 PM
Binkowski's Avatar
Binkowski
I highly recommend going with an aftermarket product. If you time it right, like holidays or Father's Day sales you can a good deal with free installation. Let a local radio/alarm shop install it. I found a basic alarm with keyless remote for $89 and it came with free installation. And while I didn't feel I needed the alarm, it got me a discount on the insurance.
Old Dec 7, 2017 | 05:17 PM
MR KROGOTH's Avatar
MR KROGOTH
I would HIGHLY recommend retrofitting a factory RKE module. I happen to have one and it's pigtails handy with all the diagrams to make it happen. Also just finished up a retrofit on my '92 F250.
Old Dec 7, 2017 | 06:19 PM
95fiveoh's Avatar
95fiveoh
I'm going to be adding an aftermarket RKE system on my 1995 F150. I hate using the key to lock and unlock the door, plus I get nervous with keys around my new paint. The Bulldog Brand System on Amazon has decent reviews and a couple people claim to have installed it on OBS trucks. It's inexpensive too.
​​​​​​https://www.amazon.com/Bulldog-KE1702-Vehicle-Keyless-System/dp/B000CS9Q6E
Old Dec 7, 2017 | 06:47 PM
terry274's Avatar
terry274
Keep us posted on how this works. I would like keyless locks but haven't tackled it yet.
Old Dec 8, 2017 | 01:17 AM
TexasGuy001's Avatar
TexasGuy001
I'd also recommend an aftermarket keyless entry or simple alarm etc. Also, our trucks have reverse polarity door locks. Depending on the model you go with, you may need relays to drive the door locks.
Old Dec 8, 2017 | 08:30 AM
Freightrain
I've used Bulldog on all my vehicles, 95 Escort, 95 F150, 89 F150, 95 F150. I've like the quality.
If you are going to get a kit, you might as well get the remote start also. That is the reason I bought them for my vehicles. The door lock was an added bonus. Though the kits are a bit more expensive.
Old Dec 8, 2017 | 09:52 AM
ifrythings's Avatar
ifrythings
The passenger kick panel has the same locks wires in it and is super easy to install the relays for the locks there. These trucks are super simple to install remotestarts and keyless entry into.
Old Dec 8, 2017 | 10:07 AM
Freightrain
Dang, who wooda thunk to use that side? Thanks for the tip!!
Guess maybe I'll get the locks hooked up now?
Old Dec 8, 2017 | 01:07 PM
Nathan7.3's Avatar
Nathan7.3
Well I don't really want to get a complete wiring harness from the junkyard and then completely tear apart the dash to install so I think I'm gonna try that Bulldog kit. So is there a write up to installing this exact aftermarket kit (or similar aftermarket kit) or is very simple to do with instructions in the kit. I have no idea so let me know.
Old Dec 8, 2017 | 02:56 PM
Freightrain
The kit has basic instructions showing the wiring for the kit itself. You have to get online to their site and check your vehicle for color codes to find out what to attach to. Not a big deal.
http://www.bulldogsecurity.com/bdnew...gdiagrams.aspx
If you are handy with electrics, you can have it working in an afternoon.
Old Dec 8, 2017 | 06:08 PM
terry274's Avatar
terry274
I just ordered the Bulldog KE1702 from Amazon for $19.95.
It should be here next week. I'll report back on the installation.
Old Dec 8, 2017 | 10:14 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
I put one of these in both my '93 trucks.They've been working good for years now.Just pull your drivers side switch,make all your splices there and the little box will fit right down inside under the switch.
If you want the parking light confirmation (the lights to flicker when you lock/unlock.I did so with my trucks) then you'll need the additional relay and do a bit more work (though worth the effort) to fish a wire through the door and up to the light switch.
