Difficulty programming Key fob
Old Dec 5, 2017 | 11:21 AM
Pocket's Avatar
Pocket
Originally Posted by Anne Gehman
Any idea where to locate the L.E.D connected to the remote start harness?? Or the remote start override button? I don't see any buttons for this.
The remote start module will be zip tied somewhere under the driver's side dash. It's a black flat box. The LED will be on the main harness about 6-8 inches from the module, and the wire lead to the override button comes off the harness right next to the LED.
Installs vary greatly depending on the tech experience, so you may have to do some fishing around under there to find everything.
Old Jul 3, 2018 | 10:10 AM
wb6anp's Avatar
wb6anp
This is from today on the 2017 Superduty forum, He wants to level the truck but keep the rake??
Has anyone installed these?
https://www.stage3motorsports.com/FD...-Leaf-Kit.html
or what HAVE you installed? I tow a 12k tag and going to level the truck and was going to use a 4.5" block out back to keep the rake but want to hear how aal's are for people. Did it change the ride? how much lift? and have you tried them out towing and did the truck sit better? Thanks
Old Jul 3, 2018 | 12:27 PM
rbentnail's Avatar
rbentnail
Uhhh, wrong thread? I do that sometimes too, mostly PWD- posting while drunk
Old Mar 13, 2021 | 05:38 PM
VannerDude's Avatar
VannerDude
OK, it's now March of 2021, and I was pulling my hair out trying to get the fob working after it just stopped completely. Cleaned the contacts, changed the fob battery (#2032), bought a new fob and....nothing.
Tried YouTube methods and.....nothing. Googled the problem and was referred back to this thread. Tried everything suggested and still nothing. Then I reread the thread and saw the recommendation to disconnect the van's battery for 10 minutes. I took the cable off and watched the clock for a complete 10 minutes. Reconnected the battery, got in the van, locked and unlocked the door, put the key in and cycled it 8 times before leaving it in the on position, at which time the van doors cycled. I then pressed the unlock button on my original fob and bingo! Then followed with the new fob button and bingo too! Finally done after a week of fiddling.
Old Mar 13, 2021 | 06:26 PM
RLXXI's Avatar
RLXXI
That's because you drive a multiplexed network of computers that resembles a van and as any tech support you may have talked to directed you towards fixing an issue computer wise is to reboot.
You rebooted your van.
Old Mar 14, 2021 | 09:58 AM
VannerDude's Avatar
VannerDude
Precisely. I still have to press the fob's door lock button twice, once for drivers rear and side, and another to get the passenger side to lock.
shadow460
2009 - 2014 F150
Jun 23, 2019 09:35 AM
EXv10
Mar 4, 2014 09:10 AM
Apocalypse
Mar 17, 2013 10:10 PM
No-Tyme
2004 - 2008 F150
21
Dec 6, 2010 04:12 PM
Vin Man
2004 - 2008 F150
Nov 26, 2006 07:56 AM
