Program Pats Key
Old Jun 22, 2019 | 11:18 PM
shadow460's Avatar
shadow460
5th Gear
Program Pats Key
The other day I had a local locksmith cut and program a new PATS key into my 2013 F-150. I only had one key and it has a keyless entry transmitter on it. I had them delete all the existing keys, reprogram the one, and program a new key.
The new key works fine but the old key will cause the door locks to cycle when I use it to switch the ignition on. That tells me it's putting the truck into some kind of programming mode.
How do I fix this? I have tried Googling it a dozen different ways and all I come up with are folks using Forscan (which doesn't work for this) and outdated Pats 1 procedures.
Old Jun 23, 2019 | 09:35 AM
alloro's Avatar
alloro
Originally Posted by shadow460
How do I fix this?
Why would you even try? You should bring it back to the locksmith that did the programming and have them correct the issue.
toys4dlr
Sep 21, 2024 06:44 AM
90pioneer
6.7L Power Stroke Diesel
17
Apr 23, 2024 03:10 PM
2civicrr
19
Apr 10, 2018 11:00 PM
Calixto
1997 - 2003 F150
Nov 9, 2014 01:09 AM
jjoyce11
2004 - 2008 F150
Jan 3, 2011 12:33 AM
