keyless entry help needed!
I got a hold or an IDS scanner and verified my code was what I thought it was.
I followed the tech folder instructions and tried to reactivate it, the only thing that did was give me a flashing keypad.
Any ideas folks on what is going on?
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the
procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once
if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Followed it last night without any luck....just went out and did it again with success.......
The key pad is still inoperable........
The keypad might be a separate issue where it went bad, lost programming, or a fuse blew.
