autolock navigator
Old Jun 4, 2011 | 02:20 PM
JEEPNFORDS's Avatar
JEEPNFORDS
autolock navigator
2nd request boys!
Every time the old lady moves the car even 1 inch, the damn doors lock!
I want this off, it know its done with the keypad on the door , just dont remember the sequence to do it!!
HELP.. 99 navigator
Old Jun 4, 2011 | 02:45 PM
pdqford's Avatar
pdqford
IIRC, you only have two choices: doors lock when the vehicle moves, or doors lock when you turn the key.
Its done with the ignition switch and the door lock button. Check the owners manual for the correct procedure.
Old Jun 5, 2011 | 12:56 PM
alloro's Avatar
alloro
Deactivating/activating autolock without the keyless entry system:
Before following the procedure, make sure that the ignition is OFF and all vehicle doors and the liftgate window are closed. You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to RUN.
2. Press the power door unlock control three times.
3. Turn the ignition key from RUN to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to RUN. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Activating/deactivating autolock with the keyless entry system:
Before following the activation or deactivation procedures, make sure that the anti-theft system (if equipped) is not armed, ignition is off, and all vehicle doors and liftgate window are closed.
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control while holding 7/8 control
4. Release 7/8 control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
To re-activate autolock, repeat steps 1–4.
fire3110
30
May 3, 2017 10:28 AM
fire3110
May 3, 2017 08:46 AM
MackGuy
May 2, 2017 01:39 PM
5.4T
16
Nov 28, 2016 06:07 PM
Patrick R.
General Automotive Discussion
Mar 31, 2016 08:59 AM
