Auto door locks
Old Sep 20, 2010 | 08:44 PM
lewis racing's Avatar
lewis racing
Auto door locks
Man, i love my ford truck,, first diesel i've had and its nothing like it.. but......
Atleast a million times a day i reach to get in the back door and its locked. If i put the truck in drive and go 3 feet,, its locked. So attempt to open back door,, its locked,, open drivers door, unlock,, and then back to back door. grrrrrr. Is there a way to defeat this??? Is there any way to un do the automatic door locks. thanks.
Old Sep 20, 2010 | 08:52 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 522pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=696 x:str><COLGROUP><COL style="WIDTH: 522pt; mso-width-source: userset; mso-width-alt: 24608" width=696><TBODY><TR style="HEIGHT: 13.6pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 13.6pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=18 width=696 align=left>AutoLock disable:</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=696 align=left>http://www.thedieselgarage.com/forums/showthread.php?t=1871</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>AUTOLOCK ENABLE/DISABLE - USING THE IGNITION SWITCH</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>1. Close all doors.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>2. Confirm that the key is in the OFF position.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>3. NOTE: Steps 3 through eight must be carried out within 30 seconds.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>Turn the key from OFF to RUN.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>4. Press UNLOCK 3 times.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>5. Turn the key from RUN to OFF.</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=696 align=left>6. Press UNLOCK 3 times.</TD></TR><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=34 width=696 align=left>7. Turn the key from OFF to RUN. The enable/disable mode is now ready to accept program changes.</TD></TR><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=34 width=696 align=left>8. Press UNLOCK once to command the vehicle security module to toggle the autolock/relock feature OFF.</TD></TR><TR style="HEIGHT: 13.6pt; mso-height-source: userset" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 13.6pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=696 align=left>9. Press LOCK once to enter the command.</TD></TR><TR style="HEIGHT: 13.6pt; mso-height-source: userset" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 13.6pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=696 align=left>10. Verify that the horn chirps one time. There should only be one chirp indicating that the autolock/relock feature has been disabled. If one chirp is heard followed by a longer sound of the horn, the autolock/relock feature has just been enabled. Return to Step 10.</TD></TR><TR style="HEIGHT: 13.6pt; mso-height-source: userset" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 522pt; HEIGHT: 13.6pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=696 align=left>11. Turn the key to the OFF position to exit the enable/disable mode.</TD></TR></TBODY></TABLE>
AUTOLOCK ENABLE/DISABLE - USING THE HARDWIRED KEYLESS ENTRY KEYPAD
A manual enable/disable mode allows the autolock feature to be turned off and on.
1. Enter the 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of entering the code, press and hold the 7/8 button on the keypad.
3. Within 5 seconds of Step 2, and while holding the 7/8 button, press the 3/4 button on the keypad and release it.
4. Within 5 seconds of Step 3, release the 7/8 button on the keypad.
If the autolock feature is disabled, the horn will chirp once. If the autolock feature is enabled, the horn will chirp once shortly and then sound a second time for a longer sound of the horn once the above sequence is completed.
Old Sep 20, 2010 | 09:05 PM
lewis racing
man, that is so cool,, i've cussed those locks for 3 years. I'm gonna give it a try. Is there any way to mess up my code on the door so that doesnt work,, since i use that quite often??.. thanks you sooooo much. Herb
Old Nov 24, 2010 | 06:16 PM
Greg Di's Avatar
Greg Di
Just tried this and it worked, but it also seemed to have stopped my keyless remote from working entirely.
Any ideas?
Old Nov 24, 2010 | 06:53 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
My keyless still works after doing this. Not sure why yours wouldn't. On the past F150, my key less controller quit working, and used my wife's, Hers was rarely used and it worked. Might be timing?
Old Nov 25, 2010 | 08:45 AM
Greg Di's Avatar
Greg Di
I got the remote to work again by going through the process and hitting LOCK in step 8 twice.
Very frustrating because I really wanted to autolock to be disabled, but not more than I need the damn remote to work.
Any ideas?
Old Nov 25, 2010 | 02:36 PM
cheezit's Avatar
cheezit
the option is also available if your truck has an information center in the cluster. just go threw the setup menu
Old Nov 25, 2010 | 03:58 PM
69cj's Avatar
69cj
If you have the owners manual it's in there. Happy Turkey Day to all.
Old Nov 26, 2010 | 08:58 AM
Outdoors1's Avatar
Outdoors1
Auto lock
I went through the process in the owner's manual and it would not disable the auto-lock. The dealer, at no charge, hooked a laptop computer up and disabled it. Since I had bought the truck used, I did not have the code for the keypad. They were able to read out the code and tell me what it was.
Old Nov 26, 2010 | 12:33 PM
Greg Di's Avatar
Greg Di
Yep. I realized this. Took three seconds to change now that I realized this was how it needed to be done. Duh...
Duey's 51
16
Oct 17, 2013 01:26 PM
Mocha Joe
Jun 26, 2013 08:28 PM
joiseystud
13
Jan 16, 2011 08:53 PM
santropez4
Nov 4, 2004 01:45 AM
