auto-lock?
Old Sep 16, 2010 | 08:07 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
auto-lock?
so my old '04 excursion and my current '98 expedition and hell even my '96 explorer all have the "autolock" thing that locks the doors once you hit like 15mph.
in my '00 limited excursion it doesnt do this, now if i remebered it was somthing you could program on/off if you wanted it or not. i looked through the whole owners manaul and can not find any info on it.
anybody have any idea if the older excursions have this and if so how to activate it?
Old Sep 17, 2010 | 12:43 AM
jh818's Avatar
jh818
Here's a copy from the 02 manual 3rd print:
Autolock
This feature automatically locks all vehicle doors when the following conditions are met:
* all doors are closed, and
* the brake is pressed before reaching 8 km/h (5 mph), and
* the ignition is in the RUN position and the vehicle is traveling more than 8 km/h (5 mph).
Relock
The autolock feature repeats when the following conditions are met:
* any door is opened then closed while the ignition is in the RUN position, and
* the vehicle is travleing more than 8 km/h (5 mph).
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your dealer, the second with a power door unlock/lock sequence and the third with the keypad. Before following the activation or deactivation procedures, make sure that the anti-theft system is not armed, ignition is off, and all vehicle doors, liftgate and cargo doors are closed.
Keyless entry key pad procedure
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control
4. Release 7/8 control.
The user should receive a horn chirp to indicate the system has been disabled or a chirp followed by a honk to indicate the system has been enabled.
Power door unlock/lock procedure
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Pressing the power door UNLOCK/LOCK button again will toggle the Autolock/Relock states.
Turn ignition to OFF to exit programming.
Old Sep 17, 2010 | 04:40 AM
shadows4's Avatar
shadows4
My 2000 does not have this feature. Don't believe it was available on the Ex in 2000 but not positive on this.
Old Sep 17, 2010 | 07:46 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
It's not on the 01 either!
Old Jul 31, 2011 | 02:12 AM
robert_l_ross's Avatar
robert_l_ross
Digging up an old thread...
I have a 2000 and happened to be on a site called "the12volt.com"
A post there claims with what looks like 4 relays, a small capacitor and a diode you can add autolock...
Add auto lock,unlock to Excursion,F250
Old Jul 31, 2011 | 02:42 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i fixed the issue by getting a 2002... sometimes miss that old '00 though.
Old Jul 31, 2011 | 02:45 AM
robert_l_ross
...wow...how much are relays in AK!?!?
Old Jul 31, 2011 | 02:47 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
the relays would not have made a difference. the '00 was totaled in a head on crash.
Old Jul 31, 2011 | 11:56 AM
ImaThorp's Avatar
ImaThorp
That's odd. I couldnt stand this feature and disabled it.
Old Jul 31, 2011 | 01:32 PM
rlh68050's Avatar
rlh68050
Yep, got it disabled on my 2010 F150 too!!! If I want the doors locked I'll lock them myself!!!
Old Jul 31, 2011 | 08:28 PM
JaySVX's Avatar
JaySVX
It was on my 98 expedition, 98 explorer and my 04 excursion. Each had it disabled with-in a week of getting them. Now if only I could disable the seatbelt alarm without rigging it...
Old Aug 1, 2011 | 01:33 PM
njneer1's Avatar
njneer1
LOL ! I find that the lock button is well within my reach while driving as well !
Old Aug 1, 2011 | 02:13 PM
dchamberlain's Avatar
dchamberlain
If you're talking about the '04, there should be a procedure to disable the seat belt alarm in your owner's manual.
Old Aug 1, 2011 | 03:52 PM
Dan Reinbold's Avatar
Dan Reinbold
https://www.ford-trucks.com/forums/8...elt-alarm.html
Works like a chime, I mean charm.
Old Aug 1, 2011 | 04:02 PM
jasonodsky's Avatar
jasonodsky
I love the auto-lock feature but well...that's just me.
JMKforddriver
Jul 12, 2017 08:42 PM
drking
2004 - 2008 F150
Nov 25, 2015 09:49 PM
Snuggyworm
Sep 24, 2015 09:00 AM
sunbelt57
Sep 10, 2012 10:36 PM
Bootlegger's Deluxe
Nov 8, 2010 12:08 AM
