Right bank is dead
Old 12-01-2017, 02:34 PM
Joey Rubino's Avatar
Joey Rubino
Joey Rubino is offline
Right bank is dead
I have an 07 F-150, it was ruining great plenty of power fired up no problem. This morning I was on my way to work and about a half hour of driving I went to get into a turn around and as accelerated out of the turn around it lost all power. It started to shake and sputter. I had it towed to a shop, he scanned it and it came up with 6 codes he didnt give me the numbers but he said that the right bank was not firing and the cam timing was off. He said it sounds like i will need a new engine... is this true? I have been reading a lot on here and from what it sounds like could this be the VCT solenoid? Would it shut the whole engine down to the point that it wont even drive above idle? Any help would be appreciated.
Old 12-02-2017, 10:46 AM
alloro's Avatar
alloro
alloro is online now
Received 4,205 Likes on 2,448 Posts
Hard to speculate without knowing what those 6 codes were.
Old 12-02-2017, 06:02 PM
F150Torqued's Avatar
F150Torqued
F150Torqued is offline
^^^^^ 100% agree
"+" there ain't no way I'd even consider letting someone (who didn't even give me the code numbers) push me for a new engine. That's ludicrous!
Old 12-06-2017, 06:50 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
what engine ?
how many miles ?
has the motor been "ticking" or chain slap prior to this ?
Yes, you could have a problem with the cam timing, chain , tensioner on that one side that would make it run VERY POORLY...... but you need some codes to get started. Hard to believe you need a new motor .... maybe a chain or adjuster or solenoid..
Old 12-06-2017, 07:46 PM
Ted928's Avatar
Ted928
Ted928 is offline
Welcome to the forum.
And based on your responsiveness, good bye.
Old 12-09-2017, 09:10 AM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
Jesus, maybe he has something better to do than sit around on the computer, like getting his truck fixed...
Old 12-09-2017, 09:18 AM
P.Bronner's Avatar
P.Bronner
Originally Posted by steve(ill)
what engine ?
how many miles ?
Yes, it almost has to be cam related. maybe it lost a tensioner and jumped a tooth or two. A VCT sysyem overhaul (solenoids, phasers, tensioners, guides, etc.) is not a small job, but probably about 1/3 of a new engine in terms of $$, assuming you're having it done professionally.
Old 12-09-2017, 10:50 AM
F150Torqued
THIS:
From a member with stastics like this:
Posts Per Day: 0.20
about a Fellow Member who has stastics like this:
Posts Per Day: 0.06
'Jesus', ease up, take a deep breath @P.Bonner.
Old 12-09-2017, 02:31 PM
P.Bronner's Avatar
P.Bronner
I have no idea what the little statistics exercise pertains to, but I breathe just fine, thanks.
-- I'm more interested in why someone who hasn't even participated in the topic is undie bunched because the OP didn't respond back to those who DID contribute. Franlky I don't care, I just want to offer ideas to the OP.
Old 12-09-2017, 03:11 PM
F150Torqued
I don't begrudge you of that.
It does, however, appear the OP is "One & Done".
Old 12-10-2017, 08:57 PM
Ted928's Avatar
Ted928
Ted928 is offline
I read threads to learn and possible offer help. Since the OP is gone, you are not offering ideas to the OP. Without the OP to provide feedback, the thread is nothing more than speculative brain storming. Dead.
My post was simply to point out that the OP is gone. The thread is dead.
Questions will go unanswered and suggestions will be unheard.
I am just not a fan of people who have the time to ask questions but don't have the time to listen/respond. I really dislike reading threads where new people simply ask the same unanswered questions, or offer the same ignored suggestions.
Maybe it is an age thing (I am 54).
Old 12-11-2017, 10:50 AM
alloro's Avatar
alloro
It doesn't get any better after that.
Old 12-11-2017, 06:23 PM
P.Bronner's Avatar
P.Bronner
Fair enough, thanks. (53 here)
pshah1211
03-27-2018 09:30 PM
Eric11973
Modular V8 (4.6L, 5.4L)
32
04-16-2017 12:35 PM
Dark Green F-150
1997 - 2003 F150
05-19-2014 12:02 PM
Fishnutz1
2004 - 2008 F150
11-18-2012 06:24 PM
IROCKWITHDIRT
Modular V10 (6.8l)
01-24-2012 02:04 PM
Quick Reply: Right bank is dead
