Timing
Old Mar 18, 2017 | 11:28 AM
Eric11973's Avatar
Eric11973
Timing
I'm lost here and looking for some help I've got a 2004 f150 5.4 the other day I was driving at around 35 mph in town out of nowhere it started stumbling backfireing bucking I got to to the local dealership and left it called the next morning and they say something broke internally and the pcm is coded bad they quoted me ten thousand dollars to replace the engine i told them no and had it towed home. When I started it to me it acts like it's lost the passenger side bank acts like it's jumped time fuel pressure is good coils are good replaced cam position sensors that didn't help I'm open to anything you have to say I'm lost.
Old Mar 18, 2017 | 01:01 PM
alloro's Avatar
alloro
You need to start by getting a code reader and seeing what trouble codes are present.
Old Mar 18, 2017 | 01:24 PM
Eric11973's Avatar
Eric11973
Oh I've got a book of codes it threw out from cam position sensors to advanced timing bank one I just pulled the passenger side valve cover off is the coiled spring supposed to be loose on the vct??
Old Mar 18, 2017 | 06:43 PM
Eric11973's Avatar
Eric11973
I'm no mechanic by no means so if I ask stupid questions it's just because I have no idea what I'm talking about so here's one if one of the guides broke or the tensioner failed would that allow the timing chain to jump also is their any way the cam phaser could move and have the engine out of time it runs just like it's out of time.
Old Mar 19, 2017 | 12:38 PM
alloro's Avatar
alloro
Yes to the jumped chain, no to the cam phaser.
Old Mar 19, 2017 | 01:12 PM
Eric11973's Avatar
Eric11973
thanks It's to cold here to mess with it Today I'll try to finish Taking it apart tomorrow after work could you give me an idea what I should be looking for after I have the valve covers and timing covers removed
Old Mar 19, 2017 | 05:05 PM
alloro's Avatar
alloro
Here is the timing procedure, pay attention to the double colored links and how they straddle the timing marks.
File Type: pdf
Old Mar 19, 2017 | 05:28 PM
Eric11973's Avatar
Eric11973
thank you very much
Old Mar 21, 2017 | 04:16 PM
Eric11973's Avatar
Eric11973
thank you very much
I finally got it apart today and thought I'd let you know what I found the passenger side timing chain guide is broken in several pieces
Old Mar 22, 2017 | 07:32 PM
Eric11973's Avatar
Eric11973
would you use motorcraft parts
Old Mar 22, 2017 | 07:49 PM
Eric11973's Avatar
Eric11973
Old Mar 23, 2017 | 09:12 PM
alloro's Avatar
alloro
For something like that...yes.
Old Mar 24, 2017 | 07:02 PM
Eric11973's Avatar
Eric11973
k thanks I actually bore scoped my engine today and everything looks good picked up my parts from the ford dealer today I've got to take the oil pan off and clean it out and then I'm going to start going back together hopefully everything will be good to go I did notice that I can move my cam phaser a good bit and the camshaft itself don't move I've checked and double checked the timing counted links and everything lines up except the passenger side has a huge amount of slack in the chain which allows the crankshaft to move and the cam stays still do you think that's what caused the timing issue??
Old Mar 26, 2017 | 08:21 AM
alloro's Avatar
alloro
Sure can be, it doesn't take much for the system to know something isn't in synch.
Old Mar 26, 2017 | 10:46 PM
wtroger's Avatar
wtroger
Did you replace the chain and the tensioner
