Level or not ?
Old Dec 6, 2017 | 08:18 PM
  #31
HRTKD's Avatar
HRTKD
Originally Posted by Xsuperdutyfan
Why wouldn't you level the truck? Other than aerodynamics what is a benefit to having nose lower. Does leveling truck effect handling and ride? Why not level it looks much better.
I don't want my truck looking stupid when I tow. And I especially don't want to be blinding people with my headlights. I think it looks fine in the stock configuration, even when not towing.
Old Dec 7, 2017 | 12:15 PM
  #32
Xsuperdutyfan's Avatar
Xsuperdutyfan
Originally Posted by cficare
And the tailgate step is easier to step onto, too. A secondary benefit I'm really getting to like is the shorter blocks have smoothed out the ride considerably. I will not deflate my tires ... speaking of which, I run 70PSI at all 4 corners.
With lowering the rear only 1-1/4"? I'd guesstimate minimal impact if any at all.
I agree these expensive Michelins on the truck wear fast enough I will keep them from wearing faster.
Checking with a buddy who does custom lifts for Ford he said it will have no effect on shocks at all.
Old Dec 7, 2017 | 12:22 PM
  #33
WyoBull's Avatar
WyoBull
I would ask the opposite question. Why level it? These trucks look great stock and IMHO, a waste of money to level them. Leveling will do nothing for you except in the looks department.
Just my opinion but then again, I like my XLT premium package truck better than my previous one which was a Lariat.
Old Dec 8, 2017 | 10:15 PM
  #34
Overslope's Avatar
Overslope
Originally Posted by Tricon
Agreed. The massive rake on these trucks stock looks hokey to me. Just slap some air bags in when you tow heavy, and look good level when you arent.
Its all personal anyways.
Agree with this. Last truck I leveled and added air bags, current truck I leveled, but added a 1" block to the rear. The block keeps a bit of rake and avoids the wormy dog look when towing. Also cheaper.
But take my opinion with a grain of salt - these were both cummins. I haven't bought a super duty yet, but I'm seriously shopping. It'll probably get leveled on the way home.
Old Dec 8, 2017 | 11:10 PM
  #35
Tricon's Avatar
Tricon
More front suspension travel, more tire clearance, longer stroke front shocks, better looks, more frame clearance over dunes.... There's plenty of reasons.
Old Dec 10, 2017 | 10:37 PM
  #36
willynilly's Avatar
willynilly
it sure seems most people are using spring spacers with shock and bumpstop drop brackets. this method will gain no extra suspension travel.
Old Dec 10, 2017 | 10:38 PM
  #37
willynilly's Avatar
willynilly
amen brotha
Old Dec 10, 2017 | 11:02 PM
  #38
Tricon's Avatar
Tricon
Everyone I know uses longer coil springs, Carli/KORE/Icon/Pure, etc.
Even if some are using coil spacers all the other points are valid.
Old Dec 10, 2017 | 11:27 PM
  #39
willynilly's Avatar
willynilly
huh ? i could probly count on one hand the people around this site using new coils instead of spacers but its not worth getting in a pissing match
yes larger diam tires do increase total ground clearance a bit and lifting the front increases entrance angle into objects and such
Old Dec 10, 2017 | 11:46 PM
  #40
Tricon's Avatar
Tricon
He mentioned above that leveling does nothing for you, just pointing out that it's not just for looks. And the Carli thread is like a billion pages long, I think there's quite a few of us that are enjoying more travel
Old Dec 10, 2017 | 11:51 PM
  #41
82_F100_300Six's Avatar
82_F100_300Six
I vote no. I bought a truck used that had it and I really got tired of it looking like it wanted to hump somebody's leg. I spent about six hours by myself with combinations of floor jacks and jack stands getting it out one day. I sure was glad I was putting the springs back in while they were shorter and not the other way around. After i was done i was sooooo happy I could see better the truck handled better and picked up an mpg or two.
Old Mar 6, 2018 | 12:58 PM
  #42
F TOO FITTY's Avatar
F TOO FITTY
Originally Posted by USSenator On my 17 F350, my towing indicator empty says a 0 degree angle. After I hook up my 39', 13K dry-weight fiver, I still show 0 degrees.
Originally Posted by roadpilot My truck drops 3", and remains level.If you parked your nose-high truck & trailer on a slight slope, the off-road status screen would indicate 0 degrees.
So if someone levels or lifts their truck and the off-road status shows something other than 0 degrees, is there a way to reset it? in other words, can you re-establish the zero setting if something is changed on the truck?
Old Mar 6, 2018 | 01:12 PM
  #43
Tricon's Avatar
Tricon
Mines leveled, shows exactly the same as before it was lifted.
Old Mar 7, 2018 | 09:26 PM
  #44
7591250sd's Avatar
7591250sd
Just IMHO, mini vans are level, not trucks. If it's level and empty - than it's not doing it's job..
Old Mar 8, 2018 | 05:31 AM
  #45
Buliwyf's Avatar
Buliwyf
Trucks should always be level. It's a design flaw to allow you to carry weight in the truck without it sagging and completely wrecking the trucks stopping ability. It's up the end user to properly set the truck up for the tasks at hand. The starting setup is just generic.
The front suspension travel is unacceptable. I want my 2" back. I'll add bags and spring cups to the rear to keep the truck level under load. Real trucks have had adjustable suspension for as long as I've been alive.
