For me personally I like the raked look. Also when I hook up to my 5th wheel it perfectly levels out.
if you tow often I say don't level. If it's very infrequent level if that's your cup of tea. Leveled and towing more often then not leaves you nose high and not only looks bad but is blinding to oncoming traffic. My opinion of course.
having been there done that, if you tow heavy a considerable amount, I would leave it stock. Even with airbags the overall behavior/handling of the truck is different towing. I towed 6500# boat and 13,500# TH before and after my modifications. The stock truck handled both the trailers better. It comes down to your usage and the looks you are after.
It all comes down to personal preference. I lowered mine a little over and inch with different rear spacers from Ford. Looks better to me. Should be ok when hooked to the 5er. No right or wrong, just whatever you like.
Is it better (or easier) to raise the front or lower the back when not hauling heavy very often?
I'm thinking most of the guys here who raise they're front ends do so to gain clearance for larger rims/tires. I'm keeping my OEM 20" wheels and lowered my aft end. Lowering the rear is easier, less expensive, and does not disrupt the steering geometry. Click HERE to see my step-by-step with photos.
I'd like to level out a little (1.5 - 2") for a better look and for 35's, but since I have a heavier 5er on the way (13.5k empty), I'm not doing anything until I see how much the rear end will squat.
Thank you, nice write up! I'll be doing this in the near future.
Now that is a killer idea. Didn't think of that be easier to load and unload stuff as well now that I'm getting older.
And the tailgate step is easier to step onto, too. A secondary benefit I'm really getting to like is the shorter blocks have smoothed out the ride considerably. I will not deflate my tires ... speaking of which, I run 70PSI at all 4 corners.
Originally Posted by Xsuperdutyfan
What effects would lowering rear have on shocks? I have the FX4 with ranchos.
With lowering the rear only 1-1/4"? I'd guesstimate minimal impact if any at all.
