Purple power on paint
Old Nov 24, 2017 | 09:55 AM
ctorres's Avatar
ctorres
Does anyone know any tricks to removing purple power white residue spot stains from truck paint. I'm trying to use soap and water with some elbow grease but to no prevail. I was using cleaning some parts and like a idiot I forgot to move or cover the truck
Old Nov 24, 2017 | 10:18 AM
Tedster9's Avatar
Tedster9
CLR should work. "Calcium, lime, rust" remover. Try it in an inconspicuous area first
Old Nov 24, 2017 | 01:00 PM
tinman52's Avatar
tinman52
Welder User
You may not get it off. Purple power contains a mild acid, which will remove paint if in contact long enough. The acid may have etched into your paint. Try some rubbing/polishing compound.
Old Nov 24, 2017 | 11:06 PM
RangerMercMan's Avatar
RangerMercMan
Car detailers use clay bars with dish soap to remove surface contaminants. After that step use a light cut polish and then a finish polish. I cannot make promises as I cannot see or feel the damage.
Old Nov 25, 2017 | 04:48 AM
Crop Duster's Avatar
Crop Duster
Industrial soap
Tinman is correct. I have a lot of experience with the damage that industrial soap can do to aircraft paint. You will most likely have to compound it until you get passed the damaged paint.
026TB4U
Paint & Bodywork
Apr 29, 2017 03:21 PM
V10man
Paint & Bodywork
Mar 18, 2013 09:23 PM
95se5m
Paint & Bodywork
Mar 7, 2004 10:51 PM
Bruker
Garage & Workshop
Mar 5, 2004 09:19 PM
