Oil Light Flickering
Old Nov 25, 2017 | 07:58 AM
Jonesy0027's Avatar
Jonesy0027
Hey Fellas,
My 65' dashboard oil light is flickering on and off. When I start it up, the light is steadily on. After driving a few minutes the oil light flickers on and off. Once warmed up goes out for a few minutes, then flickers.
​​​​​​​Any input is greatly appreciated.
Old Nov 25, 2017 | 08:28 AM
6t6merc's Avatar
6t6merc
Which motor? If an FE, fill it to the add mark and add one more quart/litre when hot. Maybe try it if it isn't an FE too...
You can temporarily plumb in a known-accurate gauge where the sender screws in to test your gauge. Most have the same thread.
Eric
Old Nov 25, 2017 | 08:49 AM
Jonesy0027's Avatar
Jonesy0027
Eric
​​​​​​​I have the L6 240 engine
Old Nov 25, 2017 | 11:09 AM
daveengelson's Avatar
daveengelson
Suggest check connectors secure, clean and and no expose wiring both at the sending unit and gauge. Also check same with the circuits running from the Constant Voltage Regulaor/Unit to the gauges, a loose or faulty regulator or connection possibly effecting the others. CVR is usually located on the back of the instrument panel. Believe the oil light is grounded at the socket to panel, if bulb is faulty or socket loose could result in poor ground. Finally, there are 2 types of sending units, 1 for gauge another type for light. Anyhow, food for thought?
Old Nov 25, 2017 | 02:20 PM
Crop Duster's Avatar
Crop Duster
That is a good schematic Dave posted but I think it only deals with a gauge. The idiot lights run on 12V and the switch on the engine is just a ground for the light and is normally closed," the light burns", at about 5 to 10 psi it opens and the light goes out. You probably just have a bad switch or the red/white wire is frayed and grounding out somewhere. Unless your rods are rattling. In that case you don't have any oil pressure and the light is just fine.
Old Nov 25, 2017 | 08:43 PM
mrpotatohead's Avatar
mrpotatohead
You are guessing unless you connect a manual gauge and read the oil pressure directly. If it's low, 6 psi or less, then you have some work to do; either a worn oil pump, severely worn engine bearings or both.
Chiefdan
May 27, 2018 07:50 PM
Upriver_WA
Mar 4, 2013 12:19 PM
59INA40
Sep 22, 2010 09:31 AM
Scifi266
Apr 10, 2007 09:46 PM
dbrad4d
Dec 21, 2006 09:52 AM
