Subwoofers?
Old Nov 19, 2017 | 05:13 PM
Odyssey350kc's Avatar
Odyssey350kc
Subwoofers?
I was wondering if anyone has installed subs in their truck? Is it possible to hook up subs using the stock stereo... the sync 3 i believe?
Old Nov 19, 2017 | 06:09 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
check under stereo upgrade all kinds of good info there, I'm running some jl slim lines in my 17s
Old Nov 19, 2017 | 08:21 PM
TufLuk13's Avatar
TufLuk13
I'm looking at adding some behind the back seats driver side. JL TW3's will fit in a custom fiberglass box back there and sound pretty good. Local shop to me has done them on a couple trucks. Quote for it was around 1400 all said and done.
Old Nov 19, 2017 | 09:22 PM
Faceplant409's Avatar
Faceplant409
Without the Sony system it’s pretty easy.
It gets complicated with the Sony system. Search upgraded stereo in the 17 psd forum.
Lots of reading.
Good luck.
Welcome!
Old Nov 20, 2017 | 04:15 AM
SloScooter's Avatar
SloScooter
We added subs, two jl w3 in the fox acoustics box and it’s loud. I have the Sony system and you might want to use a jl clean sweep, DSP to keep the signal clear. Other than that, simple install
Old Nov 20, 2017 | 07:37 AM
GABAR's Avatar
GABAR
The JL AUDIO Clean Sweep has been discontinued for almost a year.
The new JL processor for OEM systems with the stock head unit are called the FIX-82 or the FIX-86.
Old Nov 20, 2017 | 07:48 AM
David1986's Avatar
David1986
I just added the Kicker Substage to my 16 F150 XLT for $475. It sounds Great for the money. To me it sounds as good as my Sony system I had in my 15 F350.
It's also a plug and play unit. My truck already had the harness for it behind to rear seat on the drivers side. Had to get Ford to turn it on.
Same unit fits the 17 + Super Duties.
Old Nov 20, 2017 | 01:57 PM
troverman's Avatar
troverman
Where did you buy this sub from? I'd like to add one to my 2017 XLT Super Duty.
Old Nov 20, 2017 | 04:30 PM
David1986's Avatar
David1986
Went through Ebay Banner Ford. They had it listed for around $519. They have a Buy now or make offer.
The Kicker Sub is made just for these trucks and looks factory. It also carries the Ford Bumper to Bumper Warranty.
Love mine!
Old Nov 20, 2017 | 04:54 PM
SloScooter's Avatar
SloScooter
I call everything JL makes a clean sweep that interfaces due to my age. Sorry for the miscommunication.
Old Nov 20, 2017 | 08:35 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
Rockford fosgate dsr 1 newst needed gadget needed to upgrade these systems . except a subwoofer upgrade ,, powered. just put in system in king ranch truck . arc audio 1200 /6 morels tempo ultras componets up front , morels tempos coaxels in rear for fill ; and the tw3 jls in a sealed box . and fosgate dsr 1 . with 360 integration mobile features , sounds very nice . verry
Old Nov 21, 2017 | 06:13 AM
troverman's Avatar
troverman
Love mine!
Thanks, will look into it.
Old Nov 21, 2017 | 11:42 PM
marysdad's Avatar
marysdad
I have a SuperCab, so not as much room as a Crew. I put a low profile JL sub in a custom box under the driver-side back seat. I put the amps behind the driver-side rear seat (one amp for the mains and one for the sub). It came with the AC inverter under the passenger-side rear seat.
Old Nov 22, 2017 | 12:02 AM
Rockinfigs's Avatar
Rockinfigs
anyone install the kicker sub which is a direct replacement for the stock sony sub?
CorvZ061
2009 - 2014 F150
Apr 15, 2014 09:43 AM
420CREW
16
Feb 16, 2009 09:14 PM
ZipDogg
Aug 13, 2006 07:49 AM
HOGman1024
Feb 3, 2006 12:42 PM
chris12
Jan 26, 2006 11:06 PM
