Headlights
Old Jan 13, 2018 | 12:04 PM
  #46
Bearhugger1933's Avatar
Bearhugger1933
My computer is acting up so I will try again,put in new dorman relays and they went bad after using light for a short while,I am using silver star ultra bulbs,don't know what is happening,has anyone had problem with theirs.going to get some Bosch relays and see if this helps. Jlm
Old Jan 15, 2018 | 10:44 AM
  #47
Bearhugger1933
Ordered two new 40 amp Bosch relays this morning,will see if these last ,if not I will put it back the way it was.
Old Nov 15, 2018 | 12:32 PM
  #48
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by mcali2
low beam. it is 2x what i had in old fogged lenses.
old thread ressurected looking for guidance on LED Bulbs.
mcali, did these bulbs prove to be good ?
any issues ?
Old Nov 15, 2018 | 01:38 PM
  #49
mcali2's Avatar
mcali2
Originally Posted by BROWN DOG KTM
old thread resurrected looking for guidance on LED Bulbs.
any issues ?
i like them. My only dislike is there is no hi beam. They say there is but that is not true. The bulb may need adjusting within itself. There are 3 screws that position the bulb inside the housing it comes in.
It was easy. The other issue was they don't attach to the bulb housing as nice as the factory Bulbs but they work.
Old Nov 15, 2018 | 04:17 PM
  #50
BROWN DOG KTM
Oh you changed the OEM headlamp Assy ?
im out on that.
Old Nov 15, 2018 | 11:40 PM
  #51
mcali2's Avatar
mcali2
No it was just the bulb. I fixed my post above. I cant seel half of what i type on my phone.. same headlight. the LED bulb comes in a housing all on it's own. the way it mounts is not factory. It did not screw on mine correctly but was able to mount them with what cam in the box. It is just not as nice as factory. The light may need adjusting as when it goes into the housing the LED may be sideways and not up and down. It will give the light a different pattern. Just adjust it by removing the 3 screws that hold the LED bulb in the LED bulb housing. Not the light housing. just know its not hard to do.
kdwellssr
Jan 3, 2021 09:52 AM
jackus
18
Aug 8, 2016 07:50 AM
quincyj34
Nov 10, 2015 03:58 PM
buckshot047
Jan 18, 2015 09:35 AM
fordtrucklover94
Jun 4, 2008 07:58 PM
